HELP!!! Possible radiator issue
Old 09 Apr 2013, 12:20 am
Default HELP!!! Possible radiator issue
Hi there,
Yes my radiator is leaking so I've been putting water in everytime I use the car (2001 Limited Edition PT Cruiser). I don't want antifreeze leaking everywhere. I can't take it in until the end of April. Now, that's been working fine but suddenly after driving it for about 10 minutes it starts to make a clicking sound that slows down when I'm stopped at a red light and speeds up as I drive. It gets louder and louder as I go and then sounds like it's going to die. The first time it happened I was almost home so I got to my parking spot and turned off the headlights and the engine died; I had not turned the ignition off yet. I tried to start the car and it wouldn't start. It turned over a bit but it was weak. I spoke to my boss who knows a bit about cars the next day and while he was there I tried to start it again and it started fine. This may have been dumb but I took it out again to see if this would happen again and within 10 minutes it started clicking again and started sounding like it was going to die.
Anyone know what this might be?
Any help would be appreciated.
Old 09 Apr 2013, 07:12 am
Default Re: HELP!!! Possible radiator issue
Originally Posted by faguin View Post
Hi there,
Sounds to me like one of 3 things.
Stuck lifters in the engine.
Slipping serpentine belt
Partially broken timing belt.
Did the vehicle ever overheat with the leaking issue?
Old 09 Apr 2013, 01:05 pm
Yes, unfortunately, but for only a couple of minutes or so a couple of times before I realized how bad the leak was.
Old 09 Apr 2013, 01:28 pm
Teekypt's Avatar
Send a message via Skype™ to Teekypt
Check your alternator as well? May not be your main issue, but it's worth looking at as well. Hopefully, where ever you take it, they'll run a diagnostic on it. Also, if you eva get into a jam where it's overheating fast, blast your heater. If your fans are working, it'll cool the engine, blowing the heat off of it. This has saved me a couple of times. And be careful w/turning your car off if it's already hot...this can be when the engine gets it's hottest and you don't want a cracked head. <3
2003, GT, "ShuggaPlum", xenon bumper kit, custom grey/black CoverKing seat covers (front & back).
Sunrise: July 2002
Sunset: June 2018
http://www.math.uh.edu/~tai/Today/Clean3.jpg
Old 09 Apr 2013, 01:36 pm
Alternator was just fixed a couple of months ago. My boss has one of those diagnostic machines and nothing showed. I just really hope it's not a major fix.
Thanks for your reply!
Old 09 Apr 2013, 01:45 pm
Teekypt's Avatar
Sounds good I've taken a pic of your post and texting it to my mechanic...gonna see what he says. not sure how soon he will answer but it's worth a start. I'll post if/when he replies.
Sunrise: July 2002
Sunset: June 2018
Old 09 Apr 2013, 01:51 pm
cruserdad1976's Avatar
im going to say the clicking is the water leaking and getting on the belts also this wil cause them to slip and the alt will not charge depending on how bad the leak is it could be spraying water on the motor
Im guessing you dont want to tackle changing the radiator it is really one of the easiest fixes on a PT but you should really not drive it till its fixed if it overheats verry many times it will be a MAJOR repair
Old 09 Apr 2013, 02:35 pm
Thank you so much for your responses. You guys are so nice. And Teekypt thanks for doing that for me. I really appreciate it. I'll will wait patiently
Old 09 Apr 2013, 06:40 pm
If you've over heated it a few times. I would severely suggest a compression check at the shop. If you have a cracked head, it could cause severe issues including the ones your having
Radiator Bleed Valve issue JoJoChan Tech & Performance Forum 7 25 Jul 2012 07:24 pm
The radiator fan [again] bogaz Tech & Performance Forum 43 23 Aug 2011 06:43 pm
Radiator fan mash35231 Tech & Performance Forum 3 14 Oct 2010 09:38 pm
radiator fan bbromero Tech & Performance Forum 4 08 Jun 2010 03:58 pm
Radiator 4b316 Tech & Performance Forum 3 26 Dec 2008 05:56 pm
