Automatic Windows
  • 1 Post By 2step
Old 09 Apr 2013, 05:02 am
Aquamarine's Avatar
Default Automatic Windows
Silly question. Why doesn't the car also come with manual window cranks? I can only open or close my windows when the engine is running. You can't operate the windows in ACC. I guess I understand the ACC thing, but still it's an inconvenience. I'm thinking about hot weather when I want to open the windows while the car isn't running. I suppose most cars are like that now, but manual cranks would be nice also.
Old 09 Apr 2013, 05:12 am
Default Re: Automatic Windows
You don't have to start the engine, just turn key to "ON".
One of the plusses of the PT was it's list of standard features - for the first few years of the PT, Air Conditioning was also standard.
Old 09 Apr 2013, 05:13 am
I have never seen automatic windows come with manual cranks to lower them, its either one or the other..
If I had to guess why they don't come like that would be because of how the the gearing/mechanisms for the rolling up/down the windows works.
Personally I am glad they don't have manual cranks in my PT... I can imagine what the manual crank would do when I roll the window down on my drivers side front window.
But you should not need the car to be running when you want to roll the windows down. Mine work when I put the key into the "run" position.
Old 09 Apr 2013, 08:35 am
sanatanadharma's Avatar
I modified the fuse box in my car so that the power windows can be opened/ closed when the car is off; the key is out of the ignition. See my post below.
Warning, this easily reversible modification does bring safety/ liability issues (as noted in the post).
Power Window Modification
Posting in stealth will not be permitted in most threads please read the forum guidelines.
Old 09 Apr 2013, 10:00 am
2step's Avatar
It's because it's a CHRYSLER so it's loaded and all tarted up. If you want manual cranks, buy a Neon.
rob342 likes this.
Old 09 Apr 2013, 03:34 pm
my friend had a neon with both. straight from the factory it had power windows in the front, crank windows in the back. it was very odd.
Old 09 Apr 2013, 06:40 pm
That is the oddest thing in the world. I've seen it before it and has confused me to this day why they would do that.
03' PT Touring Edition 63k
Old 10 Apr 2013, 05:02 am
Aquamarine's Avatar
My last car was a Neon.
As far as the "On" position, I never thought of trying it.
automatic carwashes mikehotwills General PT Cruiser Discussions 16 31 Jul 2004 11:06 pm
Automatic Windows - UP technobear Interior Accessories Forum 10 07 Jul 2004 07:11 pm
PT GT AUTOMATIC 1MEAN PT General Turbo Discussions 15 30 May 2004 05:21 am
40-45 MPH Vibration in a new '02 PT Automatic Mopar Madness Tech & Performance Forum 14 31 Jan 2003 11:44 pm
