ignition switch wont turn to start postion
Old 11 Apr 2013, 07:20 pm
Default ignition switch wont turn to start postion
I have a 2001 pt cruiser automatic transmission. the car will not start. the starter is new all the relays are good and i replaced the ignition key cylinder. i brought it to my mechanic and he said that i need to replace the steering column. i been looking for a used steering column but no luck finding one. and the dealership wants to charge $1200 for a new one. my mechanic said that the key wont go to the start postion. does anyone know what part inside the steering column would be causing the problem? Also i found a steering column for a 2002 pt cruiser the junk yard said that it was a little bit different. i was thinking i could take the part out of the 2002 steering column and replace it in my 2001 pt cruiser. unfortunaly i have no idea what mechanical part is broken. has anyone had this problem if so please help. thanks guys
Old 11 Apr 2013, 07:36 pm
Default Re: ignition switch wont turn to start postion
It's called The ignition actuator, it's made by dorman and costs appx $34. Look on rockauto.com or the autozone website
Old 11 Apr 2013, 07:38 pm
You need this Ignition Switch Actuator Pin Assembly
https://www.google.com/search?q=dorm...h+actuator+pin
Old 12 Apr 2013, 08:57 pm
Thumbs up Re: ignition switch wont turn to start postion
Thank you so much for your quick response. I bought the switch activator but haven't had a chance to install it. I did take out the one and it is broken. You saved me a lot of time and money. Great to know their are people Out their willing to take the time and help out other People. Your the man and I can't thank you enough.
Ryan
FS: 2008 OEM 'Combo Switch' (turn signal/headlight switch) Maxxam Classifieds: For Sale/Trade 3 08 Aug 2017 06:23 am
pt wont start? ignition lights remain on. conrad Tech & Performance Forum 1 05 Nov 2012 09:16 pm
Ignition key will not turn buckeyeborne Tech & Performance Forum 4 07 Sep 2010 08:32 pm
Aftermarket radio wont turn on and off with ignition Samson Sound and Security Forum 8 23 Jan 2010 12:09 am
Key Won't Turn in Ignition twobits48 Tech & Performance Forum 6 29 Mar 2006 07:34 pm
