i would go with what the tires states on them.
Mole'@DCR 2004 SRT-4 built 2005 SRT-4 mole' 16g bws setup. 380hp 444tq 11.7@122 100% stock motor/head/axles. Dsp tuned. 2003.5 MazdaSPEED Protege stock 2004 PtGT Atx BWS SETUP and a few bolt ons. stay tuned for dyno #s Contact me for all your BWS/DCR needs.......... |
Most tires have multiple applications so what's on the tire is the maximum pressure for the tire. The pressure listed on the door is what is recommended for that car. Always go with what's on the sticker on the door or what's in the manual.
![]() Quote:
Try putting 32lbs in tires on 17" rims..........it wont be pretty. What i usually do is look at the tire, AND the door. if they match, sweet. If the door says 32psi and the max load is 28, i put 25 :-) Just dont over fill them, youll be able to feel if you underfill them :-) |
The Tire pressure is what most of us that do performance driving go by. i.e. my F1's are 50psi max rated my door jam say 35psi max. If I were to run 35psi max and compensate for heat expansion I would be all over the road on turns because of under inflation. That would be over 27% less then the maximum tire pressure. The tire would also wear on the outside portion of the tire. Now if I run 42psi the car will handle well and the tire will wear evenly.
You can always take chalk and draw a think line across the thread and then play around with different tire pressures to see what is the over all best pressure to use. Who knows it may turn out to be the "door jam jock" recommendation? Naturally I have 4 cornered weighed my cars! ![]()
To view larger pictures simply "click " on the picture! Dalai Lama "Share you knowledge. It's the best way to achieve immortality." ASE MASTER TECHNICIAN ![]() ![]() Last edited by NitroPT; 25 Apr 2013 at 03:26 pm. |
Sorry. Somehow missed that part. I did go to the tire exchange calculator and it recommends not using this tire. Its outside the 3% size difference.
That tells me it was not put on at a tire shop. Odds are a second hand sale and the previous owner just didnt give a hoot.
A man brother! I see a lot of excessive outer tire ware, when they go by the door.
![]() ![]() ![]() ![]() 03 Dream stock___________________________ 04 Touring turbo lite stock_________ 02 Touring stock_____________________ The "Three Amigos" __________________________________________________ __________________________________________________ ___________Performance, Body and Service, OEM This Is my project page. http://www.ptcruiserlinks.com/forum/...oject-1-a.html This is a great read from one of our own! Badglas badglas.blogspot.com Last edited by Busted_PT; 26 Apr 2013 at 07:08 am. |
![]() Quote:
Thread Tools | |
Display Modes | |
Tire Pressure | TaylorMade | General PT Cruiser Discussions | 15 | 10 Oct 2013 10:08 am |
Tire pressure | 1lowufo | Tech & Performance Forum | 2 | 10 Mar 2010 09:23 pm |
Tire pressure recommendations | OurPTGT | General Turbo Discussions | 11 | 14 Oct 2004 09:22 pm |
15" tire pressure? | Brad Vandrasik | Wheels, Tires, Suspension | 6 | 03 Dec 2003 11:22 am |
Tire pressure | lip | General Turbo Discussions | 2 | 10 Aug 2003 06:38 pm |
