Half way through timing belt replacement.
Like Tree7Likes
Old 27 Apr 2013, 11:47 pm
Default Half way through timing belt replacement.
Got the bracket off and need to install new belt and tensioner. Belt broke so how do I get timing right?
Old 27 Apr 2013, 11:55 pm
Default Re: Half way through timing belt replacement.
Same way the manual says.
Make sure it is at 0* TDC, install new belt, rotate 360 and make sure the marks line up :-)
Old 28 Apr 2013, 12:08 am
No book, just using Internet info so far. Any good threads on here? Unable to find using search. What's best manual to use?
2002 PT Cruiser 2.4
Old 28 Apr 2013, 12:11 am
Here is a free PDF OEM Mopar shop manual for the 01-04 :-D
Courtesy of pt dog
Free 01-04 PT cruiser shop manual
We've tried it, its virus free :-)
Hope this helps
Old 28 Apr 2013, 07:44 am
Also, if you go into the Tech & Performance section of this forum, there's a Sticky thread entitled "HOW TO". Inside that, there's about 30 links of useful information and I put about 5 that deal with the timing belt including Tips and Tricks.
Old 28 Apr 2013, 10:17 am
Thanks, amazing how much helpful info this site has!!
2002 PT Cruiser 2.4
Old 28 Apr 2013, 10:19 am
I know right!?
We dont charge like answer.com either :-p haha
Old 28 Apr 2013, 01:07 pm
Check out the thread harmonic balancer and crank sprocket removal and install tips and tricks. In the tech section. Has some detailed pics of the timing marks.
Old 28 Apr 2013, 01:22 pm
I've just added that to the HOW TO sticky with the other timing belt threads. Thanks.
Old 28 Apr 2013, 01:57 pm
Thanks I hope it's a good visual aid to the other threads there.
Timing Belt Replacement MarkB Tech & Performance Forum 108 08 Aug 2017 12:59 am
Timing belt replacement LRSRTGT General Turbo Discussions 2 06 Aug 2012 01:43 pm
Timing belt replacement dewey68 Turbo Performance 13 16 May 2012 09:53 pm
Timing belt shield, belt replacement. jdwalk04 Tech & Performance Forum 13 14 May 2012 10:01 am
Timing belt replacement? mojogator Tech & Performance Forum 3 12 Nov 2003 03:30 pm
