Broken wheel stud
Old 28 Apr 2013, 08:52 am
Default Broken wheel stud
Hello , My wife's car has a two broken wheel studs, right side, front and back . I have a manual that says to use a press device, local auto stores loans tools butthey dont have such a tool . I have a C-Clamp , but the end swivals, and both wheel studs are broken and inside. What about just pounding it out with a punch and hammer, or will that damage the spindle hitting it . I have seen how it says to replace them by just tightening the lug and pull it threw.Any help is much appreciated.I would just go ahead and try but would like to have someone that has done it so I dont mess it up. Thank you
Old 28 Apr 2013, 09:08 am
Default Re: Broken wheel stud
Yes, you should be able to punch it out. Just be careful. But here's some internet results:
http://www.nicoclub.com/archives/how...heel-stud.html
http://www.ehow.com/how_5484703_remo...eel-studs.html
Old 28 Apr 2013, 09:17 am
UptownSport's Avatar
Yep!
Just removed ten from PT hub with a 'Ford Tool'
Old 28 Apr 2013, 10:03 am
Originally Posted by UptownSport View Post
Yep!
I thought that was a "soviet tool" haha
Old 28 Apr 2013, 10:50 am
Plum, your thinking of the wrong tool.
This is what he needs.
Old 28 Apr 2013, 10:55 am
Hey...when your beating something with a hammer.....does the type really matter that much :-p hahahha
Old 28 Apr 2013, 11:04 am
The Hammer, NO but using a sickle to try and get the broken studs out with that hammer isn't gonna do any good. Might scratch everything up a bit.
Old 28 Apr 2013, 11:09 am
True....unless that is one SHARP sickle haha
Old 30 Apr 2013, 05:35 am
Didn't the Air Force pay $200 for a hammer like that?
Old 30 Apr 2013, 06:49 am
Stud has a shoulder that sticks past hub (Shorter than disc face, obviously) so there's always something sticking up when threaded part breaks off
Question apon part broken in wheel well ptcruisn Feedback and Support 1 24 Jan 2013 03:56 am
Wheel Stud Replacement kon Tech & Performance Forum 3 17 Jul 2012 01:53 pm
Broken timing belt/broken valves DreamCar Tech & Performance Forum 17 13 Mar 2012 01:35 pm
broken exhaust stud at manifold imalittleturt Tech & Performance Forum 4 03 Jan 2011 04:03 pm
Broken exhaust stud royarchr General Turbo Discussions 9 02 Nov 2004 06:55 pm
