Thermostat question? Has been leaking
  • 1 Post By Busted_PT
Old 29 Apr 2013, 10:11 pm
Default Thermostat question? Has been leaking
I have a leak from the thermostat housing. Its been leaking for some time. Is there a trick to getting it to seal and how does it mount? Does it need to be in a certain way, since it not centered perfectly on the thermostat itself. Took it out, before realizing it might not be like the rest I have replaced.
2002 PT Cruiser 2.4
Old 30 Apr 2013, 06:53 am
UptownSport's Avatar
Default Re: Thermostat question? Has been leaking
plastic housing will warp- Being cheap, i've used oversized washers, drilled brass inserts, and other things cheap people do.
Old coolant will corrode both surfaces on the water neck, and leaking cap will make it look like thermostat seal is leaking
Old 30 Apr 2013, 08:07 am
A loose overflow hose will run coolant down the side as well. Housing will also crack. Tstat should be center the hole as you look down through the neck.
UptownSport likes this.
Old 30 Apr 2013, 08:48 am
Couple of pics to help you understand.
Old 01 May 2013, 11:45 am
The dealer had no thermostats and had no clue when they would. Said there were problems or something they were working on. Any one heard this?
2002 PT Cruiser 2.4
Old 01 May 2013, 01:39 pm
Send a message via AIM to mole
where is the leak coming from?
was the t-stat gasket installed correct?
Mole'@DCR
2004 SRT-4 built
2005 SRT-4 mole' 16g bws setup. 380hp 444tq 11.7@122 100% stock motor/head/axles. Dsp tuned.
2003.5 MazdaSPEED Protege stock
2004 PtGT Atx BWS SETUP and a few bolt ons. stay tuned for dyno #s
Contact me for all your BWS/DCR needs..........
Old 01 May 2013, 04:35 pm
Found oem on eBay. Gasket was In bad shape so might have been there. Bolts might have been loose. Heard radiator cap could appear to make housing leak.
2002 PT Cruiser 2.4
180 degree thermostat question moparbbad Turbo Performance 11 20 Jun 2015 08:02 pm
quick question 04 pt leaking alot of water out of moisture tube ac off strokedoutss General Turbo Discussions 9 28 Nov 2012 03:10 pm
Replaced Thermostat 06 PT Getting Engine Light ERROR P0128 Coolant Thermostat aluisi Tech & Performance Forum 1 20 Nov 2012 06:47 pm
01 leaking from Thermostat housing, Please help gdarst Tech & Performance Forum 11 06 Jan 2010 06:52 am
Water pump leaking at 38,000, have a question... Rumble Tech & Performance Forum 8 30 Dec 2008 07:12 pm
