HELP! 2006 PT Touring 2.5L DOHC
Old 01 May 2013, 02:33 pm
Exclamation HELP! 2006 PT Touring 2.5L DOHC
The other day, my timing belt broke and of course, the car died on the side of the road. I've just had someone put a new timing belt on and we tried to crank it and ... nada. He says that the valves are warped and it will need a head job. My questions ... 1. How much money am I looking at? 2. What will it entail (valves, water pump, etc.)? 3. The car has 123,000 miles on it ... is it worth it?
Please help. This is my only car and I must have a car. Should I put the money into the car or try to get a different one?
Any help is appreciated.
Thanks!
Old 01 May 2013, 03:43 pm
Ray_Dockrey's Avatar
Default Re: HELP! 2006 PT Touring 2.5L DOHC
The first thing to ask is has this guy did a timing belt on a PT Cruiser before? The Cruiser's are pretty difficult to get in time and if he doesn't know what he is doing then it can cause these kinds of issues.
The valves hitting each other does happen but not often. How fast were you going when it broke?
Old 01 May 2013, 05:30 pm
He wasnt the same guy who changed it out for you at the 100,000 mile maintenance interval was he?
Old 02 May 2013, 02:04 am
Busa: You are a cruel cruel man.
Aubie: Flooded? --- Timing marks aligned? --- Getting spark? --- How did he determine the valves were bent?
Old 02 May 2013, 04:28 am
[/B]
Old 02 May 2013, 08:53 am
Thanks!
Ok, it's more than likely that it not timed correctly. Both cam sprockets have an up arrow as well as the timing marks that need to line up through the center of the cam bolts. Have them pull the top cover and the plugs and run turn it to top dead center and check the marks. If they are off you will see they won't line up.
Chrysler dealers have gotten wrong . It's not that uncommon to have that happen.
Old 03 May 2013, 02:45 am
Busa; Enjoyed your sarcasm. My guess is that many people disregard the maintenence, and run'em till they die; then blame the car. In this economy [the last decade], I can understand that. They could have bought a used car, and the former owner was lax on maintenence?
When foreign car owners buy a new car they just bring it to the dealership. And pull out the plastic. When the dealership replaces their timing belt, they call it 'scheduled maintenence'. When a PT breaks a timing belt at 120,000, it's called a junk car.
Tags
head job, timing belt, valves
needed info about 2006 pt touring soulgypsy76 General PT Cruiser Discussions 1 24 Sep 2012 10:16 pm
2006 PT Touring Value peterpica General PT Cruiser Discussions 13 31 May 2012 04:56 pm
2006 Manual Touring Ed discovering06 Tech & Performance Forum 9 10 Jan 2012 12:20 pm
help with flames for 2006 pr cruiser touring metraluk Exterior Accessories Forum 23 13 Nov 2008 12:09 am
2006 Touring Edition discovering06 Wheels, Tires, Suspension 3 08 May 2008 05:40 am
