Skeaky brakes....any help
Old 02 May 2013, 01:22 pm
shelbyzman's Avatar
Default Skeaky brakes....any help
My brakes make noise (skeaky) mainly the first few stops I make. Doesn't do it all the time. The car stops good...any ideas? Do I need to replace anything?
2007 PT Cruiser GT 5-speed 17x8 Konig Inception wheels K&N style intake auto throttle body Spec D tail lights Blow off plate 10.2mm plug wires Cat-Back "DNA Motoring" exhaust w/ Thrush glasspack "blacked out" DIY ground effects added boost gauge (in place of analog clock)
Old 02 May 2013, 02:13 pm
Default Re: Skeaky brakes....any help
front? if the pads are still pretty meaty and it really bugs you, you might want to put some of this on the back of the pads.
Old 02 May 2013, 02:17 pm
edb edb is offline
The pads I am using are Wagner ThermoQuite, they are quite.
Old 02 May 2013, 03:13 pm
shelbyzman's Avatar
I may try something like that. They don't shutter or shake at all
Old 02 May 2013, 07:10 pm
Need to have them checked. If they are worn out the squeaker will make noise to save you a rotor.
Old 02 May 2013, 07:49 pm
Your not saying if you have drum brakes on the rear or if the noise is definitely coming from the front or back. If from the back, it might be built up brake dust inside the drum and needs to be taken off and all the dust blown away. Be careful, it's probably toxic so you don't want to blow it towards anyone. I had that problem till I swapped shoes.
Old 03 May 2013, 02:22 pm
shelbyzman's Avatar
I figured that, but they don't make noise some days and other times it does. It doesn't shutter at all, the car stops good??? The pads don't look bad either
Old 05 May 2013, 02:31 am
Is the noise is related to humidity? If so, changing pads/pad material might help.
Old 06 May 2013, 10:01 am
shelbyzman's Avatar
It could be humidity related, not sure...it didn't make a noise while driving it this weekend. It was rainy & damp.
Brakes Darylh Tech & Performance Forum 0 22 Feb 2012 12:04 pm
brakes... superpug666 Wheels, Tires, Suspension 2 15 Jul 2009 05:08 am
Bad Brakes Sherri7391 Tech & Performance Forum 14 28 Oct 2005 03:26 pm
Brakes? purple people eater Turbo Wheels/Suspension/Handling 1 23 May 2005 09:05 am
New Brakes... matt87951 Tech & Performance Forum 26 27 Apr 2005 02:38 pm
