Help with torquering cam sprockets!
Like Tree7Likes
Old 03 May 2013, 01:54 pm
Default Help with torquering cam sprockets!
Whats the trick to tightening the cam sprockets to the 85 lb's? Using basic garage tools preferably
Old 03 May 2013, 02:39 pm
Default Re: Help with torquering cam sprockets!
Old 03 May 2013, 02:40 pm
are you asking because they rotate, or because you have no torque wrench?
i didn't torque mine, just buzzed them on with the impact gun and called it a day. it's been fine for 35,000 miles so far. IMO it's not very important unless you're dealing with bearings or gaskets.
Old 03 May 2013, 03:53 pm
so what was your psi at the gun which would make a reasonable guess why they didn't loosen on you!
Old 03 May 2013, 03:58 pm
If you don't get them tight enough, it can shear the pin on the cam.
UptownSport likes this.
Old 03 May 2013, 04:05 pm
haaa-i new you'd like that. i used the "little" snap-on 3/8 drive impact. iirc rating is 425 ft/lbs. i probably could have made bad things happen if i tried hard enough.
NitroPT likes this.
Old 03 May 2013, 05:00 pm
I don't think this is considered standard equipment. Just wack the boxed end wrench with a big hammer.
Old 03 May 2013, 05:33 pm
Send a message via AIM to mole
some things you can skip on a Torque wrench but i would NOT on these. thats just my .02
you can barrow a torque wrench from a local auto parts store.
Mole'@DCR
2004 SRT-4 built
2005 SRT-4 mole' 16g bws setup. 380hp 444tq 11.7@122 100% stock motor/head/axles. Dsp tuned.
2003.5 MazdaSPEED Protege stock
2004 PtGT Atx BWS SETUP and a few bolt ons. stay tuned for dyno #s
Contact me for all your BWS/DCR needs..........
Old 03 May 2013, 09:24 pm
When I did mine, I was able to use a curved jaw vise grip on the cam you are tightening.
I know it sounds scary, just do NOT clamp it on anything important, like a lobe (duh).
I clamped it on a non machined surface, and rested it on the edge of the head.
85 foot pounds is really not that tight, so the grips held with no problem and did not damage any surfaces involved.
There is a "special tool" mentioned in the service manual that holds the cams from turning, but of course I do not work at a dealer, and had no access to one.
A still runnin' 01 Limited,,all with a little prayer, and a lotta elbow grease
Red tint tails, chrome trimmed grille, custom towel rack buttonless flamed shifter, auto dimming rear view, Homelink remote transmitter, driver seat drawer, MOPAR sub, lowered 1" rear, MOPAR/Borla dual tipped exhaust, chrome trimmed GT gauge/airbag surround, front 35% tint, and the ever so important Fuzzy Dice
Old 04 May 2013, 07:33 pm
rcktpwrd's Avatar
hold the cam gear with a strap wrench .
Joel
www.rcktpwrd.com
cam sprockets twrh111 Tech & Performance Forum 1 12 May 2011 07:51 pm
