0031 Code
Old 04 May 2013, 06:32 pm
ejstith's Avatar
Default 0031 Code
My PT has a 0031 code. Troubleshoot says " The PCM detected the O2 Heater circuit is out of acceptable range low. Possible Causes: O2 assembly is damaged or it has failed O2 heater element (bank one) is damaged or has failed O2 heater control circuit is shorted to ground PCM has failed "
Where is the 02 heater element? 02 = Oxygen Sensor? Bank one?
2005 PT, Limited turbo Lite. Automatic all whistles and bells.
Old 04 May 2013, 08:09 pm
Default Re: 0031 Code
The heater element is inside the 02 sensor itself. The PT only has 1 bank. The code usually says something like Bank 1 sensor 1, or bank 1 sensor 2 meaning the exhaust manifold 02 sensor or the CAT 02 sensor.
Probably best if you replace both upper and downstream 02 sensors. If one is bad, the other is sure to follow awhile later.
Old 05 May 2013, 02:20 am
ej; check the wiring, too.
Old 06 May 2013, 02:20 pm
ejstith's Avatar
Thanks y'all. That bank thing had me goin'. Bank? I was thinkin' cylinders 1 & 2 bank 1, 3 & 4 bank 2 or some goofy thing. I guess they use the same code for a V engine. Thanks for the pic Cruzin ... !! Oh, the light has went off. But I've had those things come & go before on other codes.... Thanks again....
Old 14 May 2013, 02:12 pm
ejstith's Avatar
By these symbols (O2 B1 S1) H how does one know which one it is? Manifold or Catalytic converter?
Old 14 May 2013, 04:21 pm
There's only one BANK so it's Bank 1 Sensor 1 that your seeing so it's the upstream sensor that's throwing the code.
Old 14 May 2013, 05:24 pm
ejstith's Avatar
Thanks Crewzin.... I went through by manual & couldn't determine which was which.... It looks like it's a bitch to get to....
Old 14 May 2013, 05:27 pm
If you look straight down the back from the top of the engine, it's right there.
Old 15 May 2013, 01:20 am
Crewzin; excellent explanation and pics!
Old 15 May 2013, 10:54 am
cruserdad1976's Avatar
it is right there but some times getting it out is a pain id run the car get it good and hot and then try OR soak it with some buster loose then start car just dont strip the threads
CODE P0339 NOW, NOT "ALL" FIXED CODE YET HarleyTom Tech & Performance Forum 0 14 Nov 2012 03:23 pm
Code 340 Shellyellison General PT Cruiser Discussions 10 12 Dec 2010 05:19 pm
05 PT Turbo error codes: 0031,0037, 0456, 2074 acuevas PT Cruiser Convertible Forum 10 08 Nov 2010 07:01 pm
code 352 coco1476 Tech & Performance Forum 5 18 Jan 2010 05:19 pm
Code Help! 1lowufo Tech & Performance Forum 1 21 Aug 2004 07:03 pm
