Valve chatter getting worse
Old 05 May 2013, 08:59 pm
Default Valve chatter getting worse
2001 Non turbo Cruiser 105k miles. I noticed slight valve chatter when speeding up about 3 months ago not bad but i hate that dreaded sound. It has progressively gotten louder to the the point its very noticeable when driving. I maintain religious oil changes every 3k and do regular maintenance. I have searched for something to help remedy this situation but i keep getting into adjusting cam shaft lifters blah blah stuff i know nothing about. Is there anything i can do to help this or should i rush this to a mechanic to have him check it out?
Old 05 May 2013, 09:49 pm
UptownSport's Avatar
Default Re: Valve chatter getting worse
DOHC, especially the PT, valvetrains are just about bulletproof.
very low oil pressure or contamination might do it-
I also find it hard to believe you could hear this engines chatter in the PT's cabin- It's well insulated.
Rod knock is mistaken for valvetrain noise in these engines.
It does sound like you may be referring to detonation, aka 'pinging'.
FYI, PT valvetrain isn't adjustable. There were about a dozen sets of adjustables made, I'd guess.
Only one of which was actually installed on a car ...
Old 05 May 2013, 10:23 pm
[QUOTE=UptownSport;475809]DOHC, especially the PT, valvetrains are just about bulletproof.
I have heard rod knock before this is NOT it. i can clearly hear it in the cabin with the windows up or down. if the AC is on i cant hear it but the chatter gets worse.
Old 06 May 2013, 12:17 am
Maybe you can use one of these and pin point exactly were the noise is coming from. If it is in fact the valve train and you have ruled out oil pressure dropping from a failing oil pump, then, just replace the lifter(s).
Old 07 May 2013, 12:43 pm
Took it into a shop today and they said cylinder 1+2 are at 190% compression and 3+4 are at 110% compression. They said it needed a valve job and it will cost me about $1400.00.
This is the last time ill probably be on these forums because i need to buy another car now im bummed beyond belief.
Old 07 May 2013, 02:02 pm
cruserdad1976's Avatar
well you can for sure do what ever but at 110% compression what is wrong with that????
Old 07 May 2013, 02:30 pm
170-225 is normal, but anything above 100psi with less than 25% difference between cylinders is OK. i'd just drive it
Old 07 May 2013, 07:45 pm
They shouldn't be making noise, though!
They should check the oil pressure- a valve job isn't going to fix that.
IF you can remove head (There's a how-to here) valves are very inexpensive.
AND, if it runs- Who cares it cylinders are 250 250 50 8????
Old 07 May 2013, 09:41 pm
Adjoining cylinders says head gasket to me. But I would drive it until you get a plan. A good time to find a buddy with skills to help you fix it down the road.
UptownSport likes this.
Old 08 May 2013, 12:23 pm
Astute observation, thanks!
Erratic starting and power locks chatter cruisinglite Tech & Performance Forum 27 21 Oct 2009 06:43 am
2004, 2.4L (non-turbo) Valve Chatter. Jabouty Tech & Performance Forum 2 15 Jun 2009 10:42 pm
180 deg. stat- worse MPG? littleblueGT Turbo Performance 8 05 Feb 2007 01:38 pm
For better or worse! Musicman The Detail Shop 3 01 Apr 2006 10:43 am
This is worse then christmas ptgt2point4 Stage Turbo Kits 9 16 Jun 2005 11:50 pm
