HELP! if you installed new design tensioner
Old 06 May 2013, 01:48 pm
Default HELP! if you installed new design tensioner
What the procedure to get it on and to the correct position. Can't find any instructions and the old style is totally different. There is a bolt in the center that is a 13mm and a spot for a 1/4" socket end to turn it either direction. Thanks
Old 06 May 2013, 02:20 pm
Default Re: HELP! if you installed new design tensioner
Half way through timing belt replacement.
Old 06 May 2013, 03:01 pm
My gates kit came with the instructions.
Old 07 May 2013, 11:58 am
I have a fancy extension cam and can see the tensioner real easy. The instructions work but have no idea how else you would see the alignment marks and know your in the right spot without it. Bought mopar kit and no instructions!! Never would have gotten without your guys help
2002 PT Cruiser 2.4
Old 08 May 2013, 02:12 am
Daven; I never tried the fancy extension camera for the right spot. However, I have had good luck with the audio test method. If I hear a scream, I know I'm getting pretty close.
Old 08 May 2013, 07:55 am
Here is a pic of that adjustment? A common automotive mirror dose the trick!
Timing Belt Tensioner Design treed Tech & Performance Forum 8 24 Nov 2011 09:03 am
Bad Design drscope General PT Cruiser Discussions 26 20 Jul 2011 12:03 pm
Looking for a dwg or rvt file for the PT design... AyeCantSeeYou General PT Cruiser Discussions 0 07 Jul 2011 09:37 pm
If You Could Design the PT Cruiser Kevin B General PT Cruiser Discussions 7 28 Oct 2004 11:34 am
new graphic design turbomangt Exterior Accessories Forum 8 24 Feb 2003 10:46 pm
