codes
Old 06 May 2013, 06:20 pm
Default codes
01 pt crusier i have a code 1490 and 1495 i know it the high and low realay circuit.i put new radiator fan still doesnt come on when up to temp is it possible that the pcm is bad"
Old 06 May 2013, 06:25 pm
Default Re: codes
The PCM is in the mix of things to check to get the fan to come on as well as the relays and 2 fuses. One in the interior fuse box, one more in the PDC in the engine compartment.
Old 06 May 2013, 06:28 pm
Default Re: codes
ok all fuse r good and i checked continuity at the pdc to fan and to the pcm and that seam to be good
Old 06 May 2013, 06:32 pm
Default Re: codes
o and the ac dotn work now all so and the car is in limpmode for the trans and the evp code
Old 06 May 2013, 06:33 pm
Default Re: codes
Best thing to do is find someone with an OBDII scanner. That can turn the high or low speed of the fan on and off and checks the PCM and relays and fan speeds.
Old 06 May 2013, 06:37 pm
Default Re: codes
i have a small scan tool i tryed to clear code but no luck my scantool wont let me turn them on
Old 06 May 2013, 06:43 pm
Default Re: codes
A/C is gone too, as well as being in limp mode for a trans and evp code
Yea, it's time to see the professionals with an up to date scan tool.
Did you by any chance just happen to pick up this PT after it's been written off by some insurance company? How did it get in this shape with all the problems?
Old 08 May 2013, 04:12 pm
Default Re: codes
no i have had the car sent new this all happend all at one time
Dash codes--not the usual OBD codes--help! chitowncruiser General PT Cruiser Discussions 5 01 Mar 2013 11:56 pm
Codes, codes, codes... Desperately need engine light help... cdc3jj General PT Cruiser Discussions 9 01 Sep 2012 07:52 am
New codes now? unioncreek Tech & Performance Forum 1 17 Aug 2012 02:20 am
CODES codes codes... Anyone know what these codes may mean are wrong? rksnow1 Tech & Performance Forum 10 16 Jun 2012 11:06 pm
