2001 pt cruiser died code 320
Old 10 May 2013, 12:00 am
Default 2001 pt cruiser died code 320
The car tries to turn on but it wouldn't the mechanic said it might be a bad wire or bad computer. What do you guys think?
2001 Pt Cruiser Limited Edition 138000 miles, Interior LED, Smocked Back Up Lights,
Old 10 May 2013, 02:40 am
chigger_ns's Avatar
Default Re: 2001 pt cruiser died code 320
P320, Crank censor
2001 PT 5 speed Touring Edition
Eibach Pro Springs, Energy Suspension HyperFlex Master Kit bushings, 17" RTX Euro wheels, K&N drop in air filter, MotoMaster flat plate AGM battery, KYB GR2 shocks and struts, Booger standard shifter bushings, Ooogah horn.
Old 10 May 2013, 07:40 am
As chigger_ns just said: P0320 is no reference signal from crankshaft position sensor detected during cranking.
On a 2001 it's pretty easy to get to. Just above the oil filter.
Old 10 May 2013, 10:51 am
I just call my mechanic and said it had broken wires
Old 10 May 2013, 11:22 am
To the Crankshaft sensor? Never heard that one before. I experienced the burnt/broken wires from the Camshaft sensor when the harness broke loose and hung down low enough on the back side of the engine to hit the spinning half shaft. First and only time my baby had to be towed. They broke 2 out of 4 under car LED lights.
Old 10 May 2013, 12:14 pm
PTJunkie's Avatar
That's why I request a flat-bed every time.
William____
2004 Bright Silver PT Cruiser Turbo GT H.O
Old 10 May 2013, 12:21 pm
11;30pm, traveling home to Florida from Virginia on I95. 80mph, engine light come on, car starts dying. Just about made it off the highway to the shoulder. Cranks but won't start. Reach for the cell (I have Chevron Travel club) and only 1 bar of power left on the phone. Had to quickly tell the travel club where I was (exit at Waterford S.C.) and tell her my phone was about to go dead, please send help. Wasn't thinking flatbed at the time....but should have.
Old 11 May 2013, 01:31 am
Chris; My chart shows p0320 = 'ignition/distributor engine speed input circuit malfunction'. ---- Imagine the possibilities!
2001 Died while driving compguy Tech & Performance Forum 3 07 Aug 2013 11:43 am
2001 PT Cruiser Limited died Tredington Tech & Performance Forum 2 07 Jul 2011 06:48 am
2001 pt cruiser p0700 code Ginz General PT Cruiser Discussions 8 14 Aug 2010 11:05 am
2001 PT Cruiser Just Died... Got codes.. Took a cab home pasikobri Tech & Performance Forum 7 08 Feb 2010 05:02 pm
UGH! Code 0442, PT Cruiser 2001 LTD, 41,000 miles tvldeals General PT Cruiser Discussions 5 08 Aug 2005 12:46 am
