Will not start possibly Neutral safety switch
Old 10 May 2013, 09:06 pm
Default Will not start possibly Neutral safety switch
Hi,
I have a 2002 PT cruiser. When the interior gets warm it will not start. It acts just like if I have it out of park. Is there a way to bypass the Neutral safety switch so I can test it?
thanks for your help.
Old 10 May 2013, 09:52 pm
Default Re: Will not start possibly Neutral safety switch
Will it turn over but no start?
Old 11 May 2013, 06:42 am
No all the light and radio work just no starter. If you I get the same response if I put it in drive and then try to start it.
Old 11 May 2013, 07:30 am
Did you try jump starting it. The battery can have power for all the lights, radio etc but not enough to turn over the engine.
Old 11 May 2013, 02:21 pm
No, I did not try to jump start it. That is really difficult with an automatic. I quess I did not explain it completely. When it is hot, it will not start. If I wait until the evening or early next morning, it will start right up. Thanks for all your help everyone
Old 11 May 2013, 03:04 pm
OK, here's some answers from Google:
So my car won't start once the engine is hot, help! - LS1TECH
engine won't start after getting warmed up and sitting. - Jeep Wrangler Forum
Won't start when hot - Car Talk
HELP please! engine won't start hot - Car Forums and Automotive Chat
Why the engine won't start when hot
Old 11 May 2013, 07:08 pm
Neutral safety switch is not affected buy heat. It's more likely your starter. When it dose it again. Have someone to try and start it and and tap on the starter it will probly start. If so replace it.
Old 18 May 2013, 06:51 pm
So I tried to replace the starter and that was not it. It has something to do with powering the starter relay. If I short the contacts it starts. I also swapped the relay with the horn and it works fine. Now for the first time there is a fault code P 1684, any idea what this code is?
Old 18 May 2013, 06:57 pm
P1684 does not indicate a problem; it's only a status, which indicates that the PCM memory has been cleared within the last 50 ignition cycles which means the battery was disconnected at some time.
Old 18 May 2013, 08:30 pm
Trace all your big connections from starter and block All the way back to the battery.
ECU Reboot, Code Clear, Safety Switch sanatanadharma Tech & Performance Forum 1 06 Jun 2013 11:22 am
Neutral Safety Switch??? Moto Tech & Performance Forum 3 21 May 2013 09:06 pm
ignition switch wont turn to start postion ryan350 General PT Cruiser Discussions 3 12 Apr 2013 08:57 pm
Where's the park/neutral switch located '02 auto? JohnGalt Tech & Performance Forum 10 22 Sep 2011 12:57 pm
Fuel safety switch brett185 Tech & Performance Forum 3 26 Apr 2011 02:57 pm
