head light problem
Old 11 May 2013, 08:01 pm
Default head light problem
Recently when I switch from high beam to low beams all the lights just turn off . If I cycle the switch again they will turn back on. This is not something that happens all of the time but if i just leave the low beams on I never have a problem. This gets annoying because I do most of my driving at night.
2001 PT Limited 197,000mi. bone stock for now!
Federal Signal LED warning lights for fire dept. use.
Old 11 May 2013, 08:05 pm
Default Re: head light problem
Very possible you have a problem with the multi-function switch that controls the lights/fog/turn signals. Lots of owners have had to replace that switch.
Old 11 May 2013, 09:58 pm
I repaired the fog light switch when i got it, can that be repaired also?
Old 11 May 2013, 10:09 pm
By fog light switch, do you mean the stalk on the steering column that works the lights?
Old 11 May 2013, 10:13 pm
Yes the switch.
Old 12 May 2013, 12:15 am
You just may be able to do so. Let us all know what you learn.
My 1990 Mazda 626 has headlight hi-low beam switch problems that I fix from time to time by disassembling and cleaning up.
Based on my experience today, check that the pins at the left side grey connector are all securely pressed in.
Head Light protection PT_Preacher Exterior Accessories Forum 8 26 Aug 2012 04:43 pm
head problem? darrellfin300 Tech & Performance Forum 11 14 May 2012 09:58 pm
how to get to head light in 05 bhunt41 Exterior Accessories Forum 6 30 Dec 2011 12:22 pm
LUMINICS head light and fog light bulbs 03baggedturbo Vendors & Buyers Forum 8 22 May 2008 08:36 am
LUMINICS head light and fog light bulbs 03baggedturbo Classifieds: For Sale/Trade 0 12 Dec 2004 09:05 pm
