Interferance
Old 12 May 2013, 07:25 am
Default Interferance
I've had a search and can only see infomation on the 2.4L engine regarding it been interferance or non interferance. What's the script with the 2.0L engine?
UK
2002
Auto
2.0L
Is it Interferance or not?
Regards
Marty
Old 12 May 2013, 07:29 am
Default Re: Interferance
Don't take my word. But uptown says interference. Try Googling it.
Old 12 May 2013, 07:31 am
Yep, there's been a couple posts that reference the 2.0 ltr engine as an INTERFERENCE engine.
Old 12 May 2013, 11:21 pm
UptownSport's Avatar
Definitely interference-
You can actually get the valves to hit pistons when their CLOSED,
if you mill enough off head, remove headgasket shim, piston is that close
2.4 is peerless in modern design, as piston can't be close to head with long stoke/small bore- Other wise compression would be like 12:1
