Errors
  • 1 Post By Ray_Dockrey
Old 13 May 2013, 08:38 am
Default Errors
hello I've just had my Girlfriend run the error check by turhing the key on and off and got the following codes
NOTE the only noticable problem right now is it's idle of 15000 revs thereabouts.
0340 Cam shaft position sensor
0134 02 sensorr insufficient actifity bank 1 (IS THE A LAMBDA SENSOR)
0551 Power steering pressure sensor
0171 Fule trim system lean bank 1
0140 O2 circuit insuffician activity bank 1
Maybe worth noting in relation to the cam position one, that whilst no noise or obvious problems are there the cam belt is getting replaced when I'm home due to age not millage
The steering feels fine
As much help as possible please. I've just read use crysler parts not copies.
HELP!
Old 13 May 2013, 09:53 am
Default Re: Errors ALSO
I have these errors with the key dance but no check angine light or warnings on the dash. Is that normal? Do they just need clearing?
Cheers
Marty
Old 13 May 2013, 10:29 am
Ray_Dockrey's Avatar
Default Re: Errors
i would disconnect the negative for about ten minutes. While it is unhooked hit the brake pedal a few times to rid of any residual power. reconnect and drive it for a while and see if it returns any codes.
cruserdad1976 likes this.
Old 13 May 2013, 11:02 am
cruserdad1976's Avatar
Default Re: Errors
what he said these could be stored codes for who knows when disconect or get a obII and clean all codes
Went form errors P0032, P0038 to P0420 after new battery cables lostdawg Tech & Performance Forum 4 15 Oct 2012 11:21 pm
