Wheel bearing issue
  • 1 Post By Matt42
Old 13 May 2013, 04:57 pm
chuckd1991's Avatar
Default Wheel bearing issue
First off, I'm not sure if I have a front wheel bearing going bad. There is a humming nose that seems to be coming from the front driver side area when the steering wheel is straight or turning left. It goes away when turning right. If it is the bearing, I did some checking and the hub and bearing assembly parts aren't overly expensive. I know that if you just replace the bearing you need to remove quite a bit of stuff, and then take the hub into some place that can press it out. I would just as soon save the extra step and replace the hub. Any thoughts?
'06 GT, Magnesium Pearlcoat.
Old 13 May 2013, 06:13 pm
Default Re: Wheel bearing issue
That is the only way to do it that i'm aware of. But it was easy to do far as these things go. Got my bearings on eBay.
Old 14 May 2013, 12:38 am
UptownSport's Avatar
The hub generally comes out of knuckle w/o too much trouble.
The outer race is still pressed on the hub, you can 'slice' it w/ a dremel.
It'll crack with a punch tap.
Bearing will hammer out of knuckle. You can use old bearing to hammer new bearing in.
Hub should be pressed-
And, BTW, hub isn't usually replaced- It's reused.
Old 14 May 2013, 11:37 am
Matt42's Avatar
You can do it either way. I have a bearing press. So for me, the decision was simple. Be double extra certain careful what brand of bearings and/or hubs you buy! Some of them are made in China and may or may not be OK. My experience with Chinese-made bearings has been mixed to bad. I won't use them. When I replaced the bearings on my 2004, I specified Timken. They were NTN bearings in a Timken box. NTN bearings are a top drawer brand and perfectly good. When you consider how much time and expense you are putting into this, saving $20 on the bearing set is, I believe, false economy.
UptownSport likes this.
1996 Dodge diesel 4X4, 2001 PT Cruiser Touring with rear disc brakes, [Now gone 2004 PT Cruiser Base 5 speed], 2007 Chrysler T&C Touring
Wheel bearing issue? dwg12 Tech & Performance Forum 2 23 Feb 2012 06:44 pm
Wheel Bearing's anyone? TrannyManny Wheels, Tires, Suspension 13 30 Oct 2011 10:14 am
Wheel bearing issue? scrisp2 Wheels, Tires, Suspension 10 26 Dec 2009 04:13 pm
which wheel bearing musicmanchuck4 Wheels, Tires, Suspension 0 08 Apr 2009 06:48 pm
