windshield washers
Old 16 May 2013, 10:27 pm
Default windshield washers
Okay need some help, don't want to go back to stock washers just to have the same problem down the road. The heat finally did my windshield washers in. I did do search and it came up everything else but windshield washers. Maybe I should use google. Ideas would be appreciated. I'm sure this is not a new problem with these cars. 2003 GT, Atx, 187,000 miles.
Old 16 May 2013, 10:55 pm
Default Re: windshield washers
Sorry nozzles that are mounted on the hood LOL
Old 17 May 2013, 03:40 am
Yep, Turbo's put out a lot of heat under the hood and the nozzels can't take it. Have seen it on the forum many times. After you replace them, under the hood blanket (you do have the hood blanket under the hood?) try duck taping some aluminum foil over the underside of the nozzels to help protect them from the heat.
Old 17 May 2013, 09:39 am
Yes I still have the hood blanket
Windsheild Washers CruzinGT General PT Cruiser Discussions 5 18 Aug 2010 03:16 pm
Windshield Washers Squirters delrosen General PT Cruiser Discussions 5 11 Nov 2008 01:54 pm
Windshield Washers WAYNEF Exterior Accessories Forum 6 23 Sep 2004 06:11 pm
LED washers ptcruz311 Exterior Accessories Forum 2 10 May 2003 03:57 am
Lighted Windshield Washers Install onyxgreen Exterior Accessories Forum 3 06 Apr 2003 04:07 pm
