P0301 help
Old 17 May 2013, 09:00 am
Default P0301 help
Hi, this morning on my way to work, My 07' PT started to hesitate and the check engine light was flashing. I pulled p0301 with my scan tool and came back home to troubleshoot. I have switched spark plugs between 1 and 4 along with the wires, and still have a misfire. I do not know when spark plugs were last replaced, but they seem to have oil on the top. Its part of the valve gasket or something from videos I have seen on that. Anyway, what would cause a 301 code besides spark plugs? Fuel injector? Fuel pressure etc? Thanks for any help
Old 17 May 2013, 09:22 am
Default Re: P0301 help
Did the code stay at P0301 after switching plugs and wires from 1 to 4 or did it change to P0304 ??? Clear the code, take a ride and find out.
Old 17 May 2013, 09:24 am
Originally Posted by CREWZIN View Post
Did the code stay at P0301 after switching plugs and wires from 1 to 4 ???
Yes, even after resetting the codes it only took a minute for it to start flashing again.
Old 17 May 2013, 09:26 am
...and I take it, it's still P0301. Check for any leaks in the upper manifold along the seams and finally, you need to do a compression check to see how cylinder 1 is doing internally.
Old 17 May 2013, 09:31 am
How do I do a compression test? Use a compression tester and pull fuel pump relay and crank it a few times? Also, what kind of fluid should I use to check for a leaky intake gasket?
Old 17 May 2013, 09:54 am
The compression test is done with the top/upper manifold off and each cylinder has to be done to see how they measure up to the others. The leaky intake can be done with WD-40 or other non-flammable spray while the engine is all together and running. Look for sounds of the engine speed changing if you happen to spray upon a leak. Be sure to spray where the upper and lower intake come together.
Old 17 May 2013, 10:18 am
Is there a way to disable the fuel pump for a compression test or is that not required?
Old 17 May 2013, 10:23 am
On the 2001-2005 cruisers it's easy, but I don't know where to test on the newer cruisers.
From what you said, I don't think you have a fuel related problem (but I could be wrong). Fuel related things seem to trigger an all-over kind of fault code, not just one cylinder ...unless of course it's the fuel injector for that one particular cylinder.
Going out now to the movies to see Star Trek, back this evening.
Old 17 May 2013, 12:12 pm
Compression results were around the same for each cylinder. Everything was around 180. I just replaced spark plugs because they had carbon build up. The new plugs are champion double platinums and replaced some autolites. Still throws p0301. I sprayed carb cleaner around the intake upper gasket but no change in idle. Bad fuel Injector maybe?
Old 17 May 2013, 05:34 pm
I'm back, Great (Star Trek) movie.
Yes it could be an bad or clogged injector. A forced cleaning at a shop of the injection system could help, if it is indeed the problem. I'm not a mechanic and it doesn't look like anyone else is jumping into the conversation so I'm all out of ideas.
P0301 code - was IAC valve Wingerbill Tech & Performance Forum 4 14 May 2012 09:54 pm
engine light P0301 stefbool Tech & Performance Forum 20 06 May 2011 06:57 pm
got a p0301 error code...help bkh67 Tech & Performance Forum 1 20 Jan 2011 06:34 pm
P0301 Code even with new plugs and wires? ottoman Tech & Performance Forum 3 10 Feb 2009 09:07 am
error code P0301 chicagocruiser Tech & Performance Forum 4 28 Dec 2008 06:06 pm
