Crankshaft damper removal tool/baring puller
Old 17 May 2013, 01:02 pm
Cool Crankshaft damper removal tool/baring puller
I can't find where to buy the crank pulley removal tool in the UK. How does it differ from a normal baring puller?
Old 17 May 2013, 01:48 pm
UptownSport's Avatar
Default Re: Crankshaft damper removal tool/baring puller
You don't need it-
I used it for years, then fount a 3-jaw worked just fine.
Ensure you pull on the hub center, NOT the outside!!
Use a bolt to press on, not an extension.
Old 17 May 2013, 03:29 pm
eBay that ships global would work.
2002 PT Cruiser 2.4
Old 18 May 2013, 12:05 am
Question Re: Crankshaft damper removal tool/baring puller
so this baring puller would eb fine?
Google Image Result for http://blogs.solidworks.com/.a/6a00d83451706569e20120a7d7f5b4970b-800wi
Cheers lads
Old 18 May 2013, 07:07 am
Originally Posted by Marty_D View Post
HARMONIC BALANCER & CRANK SPROCKET REMOVEL AND INSTALL TOOL AND TIPS!!!!
Try this if you want to save some cash.
Can't get crank damper off!!! bretthammy Tech & Performance Forum 6 17 Mar 2013 09:03 pm
Special tool necessary for Installing Crankshaft dampner pulley? 2001PTCRUZ Tech & Performance Forum 4 14 Jan 2013 10:12 pm
harmonic puller dingdangdo Europe PT Forum 8 01 Dec 2012 07:28 pm
Crankshaft BACdaG1 Feedback and Support 0 09 Nov 2010 09:36 pm
Crankshaft damper won't come off!! able2able Tech & Performance Forum 7 03 Jun 2010 09:48 pm
