tick tick tick loud noise :-(
Old 18 May 2013, 01:00 pm
reaper's Avatar
Default tick tick tick loud noise :-(
My manual pt has developed a rather loud ticking noise , pressing the clutch peddle stops the noise , im thinking its the release bearing . . . Does this sound right ?
And if so is there anything that can be done without dropping the box ?
Thanks in advance
Old 18 May 2013, 11:57 pm
UptownSport's Avatar
Default Re: tick tick tick loud noise :-(
Could be the bolts that hold flexplate to clutch becoming loose- Classic symptom.
Old 19 May 2013, 12:50 am
Grim; check for freeplay in the clutch fork. The fork should not touch the throwout bearing with the clutch pedal up. This usually doesn't cause a loud noise, but worth a try.
Old 20 May 2013, 12:43 am
are you sure?
The cable trans TOB was designed to run in contact (Why????), at least that's what FSM said.
I'd assume hydraulic is same
Old 20 May 2013, 01:21 am
Uptown; No, I'm not sure. But constant contact of the fingers of the pressure plate and the throwout bearing might cause premature wear? The older cars had a little spring outside the bellhousing to pull the bearing off the fingers. The new stuff might be different.
Old 20 May 2013, 11:41 am
reaper's Avatar
Thanks for the replys , looks like there is nothing for it but to drop the box and see . . . .dam
Old 20 May 2013, 03:38 pm
I said 'WTF' When I read it too
Old 21 May 2013, 01:42 am
Reaper; before you pull the tranny, check the flex-plate bolts like Uptown said. Also, check for hairline cracks around the bolts. --- And bleed the slave cylinder to eliminate any air pockets. And try to find out where the noise is coming from before you pull the tranny.
reaper likes this.
Old 21 May 2013, 02:49 am
Uptown update; I looked up the parts manual for 06-08 [from tech and perf.] and found the diagram of the clutch systems. page 58 and 59, fig. 6-310 and fig 6-320. As I read it, the turbos are radically different than the non-turbos relating to the slave cylinders? Complication breeds confusion. --- Deep huh?
Old 21 May 2013, 11:34 am
reaper's Avatar
Thanks man
Will check them over and get the stethoscope out to try pin-point the noise
loud noise from front end...cooling fan? Bonecruiser Tech & Performance Forum 4 27 Nov 2012 11:05 pm
Wobble. Loud noise! What do i look for? matthewmilbut Wheels, Tires, Suspension 22 10 Feb 2011 01:37 pm
Loud noise repost! Please help matthewmilbut Tech & Performance Forum 0 07 Feb 2011 11:03 pm
very loud high pitched noise Triplecat2002 General Turbo Discussions 6 30 Nov 2009 08:53 am
Loud Ticking Noise (please help) alnewp Tech & Performance Forum 6 08 Mar 2009 07:41 am
