Right wheel gets bumpy at 75 mph
  • 1 Post By Gamer92
Old 18 May 2013, 04:50 pm
Default Right wheel gets bumpy at 75 mph
Hi everybody,
Today as I was driving on the highway I realized that when my PT hits 75 mph (more or less), a rapid bumpy sound generates from the front right of the car (I assume from the wheel). It sounds as if I were driving on a rumble strip, just that I'm not :-/
Today it's Saturday, and tomorrow Sunday, so it's unlikely I'll have the chance to bring it to an autorepair before Monday, and I have a 2 and half hour drive to make it back home. What could it be? Should I be concerned? The noise doesn't seem to happen if I drive within 70 mph. No other feeling to report.
Thoughts?
Thanks a lot. It's my first car and my first PT so I'm not very experienced...
Old 18 May 2013, 05:15 pm
Default Re: Right wheel gets bumpy at 75 mph
It's a busted shock. It could be dangerous if you try to go that fast. So If you are going to drive home. Keep your speed well under your symptoms. I have drove worse and further. Be especially careful when turning left and the weight shifts to that side. If it bounces slow down more. Just take your time and give yourself plenty of room.
Old 18 May 2013, 05:27 pm
What I thought and feared.
Is it going to be very expensive?
Old 18 May 2013, 05:41 pm
If its indeed the front yes. Shop around You will need to do them in pares. Both sides.
Old 18 May 2013, 08:45 pm
In the order of? 1000? 2000?
What if I just go slower than 75?
Old 18 May 2013, 10:09 pm
Not that much unless you go to the dealer. You diffidently should until you get home and can get it done. It will git worse.
Old 18 May 2013, 10:16 pm
You can try AutoMD.com for an estimated cost.
Busted_PT likes this.
Old 12 Jun 2013, 02:47 am
Hi all,
I just wanted to give you a quick update. On the way back home I drove slower, and didn't have problems. This leaves me a mixed feeling, as in I did experienced again the bumping at slower speeds, but in a couple of moments I didn't at higher speed. I noticed I have some plastic piece hanging down below the car, which has me wondering if, with wind and speed, it's what bumps, depending on the situation.
Also, the previous owner, a friend of mine, reported the same issue to both Chrysler and a car engineer, and they both concluded that it was not the shocker.
Since in August I have a long trip of 12-13 hours I'll have the car checked out for fluids and regular stuff, but I'm not sure if, and how I should bring this up in order not to be fooled.
Old 12 Jun 2013, 07:21 am
Hi all,
If you feel a bump then you may hay a shock or other suspension problem. As we assumed. But if you heard a bump then ge that peace re connected or removed. Take it out on the highway and run the speed you first had the problem.
Old 13 Jun 2013, 03:46 am
sid; check tire pressure first. Then bring to a garage to have the tie rods and other suspension parts checked to be safe. Then have both front tires balanced. Bad shocks/struts will increase the vibration.
Groan/creaking sound when turning wheel right (front right wheel) 2k2ptc Wheels, Tires, Suspension 8 02 Sep 2012 10:52 am
04 bumpy ride fishntoss Wheels, Tires, Suspension 10 26 Feb 2012 12:07 pm
out of curiosity banging on bumpy road chryslergirl Tech & Performance Forum 2 14 Jul 2009 06:58 am
advice on "noise" on bumpy roads... comPuTer General PT Cruiser Discussions 1 24 Mar 2009 02:40 pm
70+ MPH & bumpy??? knowyourturbo Wheels, Tires, Suspension 9 26 Jan 2004 11:50 pm
