Did the mechanic damage the alternator belt?
Old 20 May 2013, 03:10 am
Default Did the mechanic damage the alternator belt?
Howdy! I have a 2005 Touring convertible that has just over 40K miles on the clock. Yes, really! I bought it used with 22K miles about a year and a half ago, and I'm pretty sure that it sat idle in a garage for a few years before that judging by the stickers on the license plate.
About a month ago, I had my right front wheel bearing and hub replaced. The mechanic who did it was new to me, but the shop has an excellent reputation and felt reputable to me.
A few weeks after that, I was flying down I-5 in central California, and heard a noise that sounded like debris in my right front wheel well. A mile or two later, I got an alternator light. I carefully drove to the next exit, and as expected the alternator belt was nowhere to be found. (AAA to the rescue! They covered the cost of my overnight lodging, then the next day found me a shop that was open on Saturday and towed me 30 miles.)
As the shop was replacing the belt I noticed that they had the right front wheel off, and I started to wonder. Is it possible that the first shop damaged the alternator belt while they were replacing the bearing?
I certainly wouldn't be able to prove it, since bits of the belt are somewhere on the side of the freeway now, but I'm curious about whether this is a likely scenario or not.
Old 20 May 2013, 03:27 am
Default Re: Did the mechanic damage the alternator belt?
The right front wheel comes off to gain access to the inner liner of the wheel well. Once that's taken off, you gain access to both the serpentine and alternator belt. The mechanic shouldn't have had to take that inner liner off for the work he did.
Old 20 May 2013, 03:38 am
Send a message via AIM to mole
i agree
Mole'@DCR
2004 SRT-4 built
2005 SRT-4 mole' 16g bws setup. 380hp 444tq 11.7@122 100% stock motor/head/axles. Dsp tuned.
2003.5 MazdaSPEED Protege stock
2004 PtGT Atx BWS SETUP and a few bolt ons. stay tuned for dyno #s
Contact me for all your BWS/DCR needs..........
Old 20 May 2013, 04:00 am
Thank you! I'll chalk this one up to coincidence.
Old 20 May 2013, 07:53 am
Dry rot of the belts from sitting is the culprit. I also agree with the above.
Old 20 May 2013, 08:30 am
PTJunkie's Avatar
Yup, dry-rot. Don't be surprised if the timing belt goes next.
William____
2004 Bright Silver PT Cruiser Turbo GT H.O
Old 20 May 2013, 08:41 am
Exclamation Re: Did the mechanic damage the alternator belt?
I am looking for a low mileage DD, and I always check the carfax. It tells you the miles when it was registered each year.
I saw a few that looked like they sat for a few years, no thanks.
Low miles is good, but sitting for a few years without being driven is no bueno either.
Def check your timing belt
Alternator belt help! supernasro Tech & Performance Forum 19 03 Apr 2014 07:38 am
Mechanic Says Timing Belt is About To Go...? Kaylad8528 Tech & Performance Forum 10 19 Oct 2012 08:59 am
tighting the alternator belt!!help! jjmommy20 General PT Cruiser Discussions 1 26 Mar 2011 08:26 pm
Help! Timing Belt damage Vicki120 Tech & Performance Forum 2 31 Jul 2009 02:38 pm
Alternator Belt Question edisapimp Tech & Performance Forum 2 22 Jun 2007 01:50 am
