Code 0031 & 0037
Old 22 May 2013, 12:55 pm
ejstith's Avatar
Default Code 0031 & 0037
Well I posted about 0031 code & I had a new sensor put in the manifold. A day later I had code 0037 so I just had a sensor put in the cat. Now the engine light is still on & says code 0031 again. Pee on it, I'm gonna run it until it won't run. If it's the cat I'll change it when it stinks !! I'm tired of messin' with it... !!
2005 PT, Limited turbo Lite. Automatic all whistles and bells.
Old 22 May 2013, 04:17 pm
chigger_ns's Avatar
Default Re: Code 0031 & 0037
I would get it checked at a shop, clogged cat can catch fire!
2001 PT 5 speed Touring Edition
Eibach Pro Springs, Energy Suspension HyperFlex Master Kit bushings, 17" RTX Euro wheels, K&N drop in air filter, MotoMaster flat plate AGM battery, KYB GR2 shocks and struts, Booger standard shifter bushings, Ooogah horn.
Old 22 May 2013, 11:08 pm
ej; have you checked the fuse? Its probably in the PDC [fusebox] which is located under the air cleaner box. I think. The codes show 'heater circuit low voltage' , which go thru a fuse to power them. 20 amp maybe?
Old 23 May 2013, 01:02 pm
ejstith's Avatar
Thanks 06, I'll check when she get's home....
Old 25 May 2013, 06:36 am
ejstith's Avatar
Well the light went out & hasn't come back on. (Yet). Guess it's not a fuse...Just hope it stays out. Getting ready to go on a 2500 mile trip. The belt is over due so hope that holds until I get back.... Thanks y'all..
Old 01 Jun 2013, 06:17 am
ejstith's Avatar
Angry Re: Code 0031 & 0037
Well, in Yorktown Va, it threw a fit & when accelerator was pushed went into limp mode for a bit then went on.. Checked code & was 2074. Took it to the Chrysler store & it was a main brain (PCM) short. $1,000 later all is well.
0031 Code ejstith General PT Cruiser Discussions 9 15 May 2013 10:54 am
Codes p0031 & 0037, intermittent power loss, anyone familiar with it? Memark Tech & Performance Forum 2 08 Jun 2011 12:35 am
Codes p0031 & 0037, intermittent power loss, anyone familiar with it? Memark General Turbo Discussions 3 04 Jun 2011 12:47 pm
05 PT Turbo error codes: 0031,0037, 0456, 2074 acuevas PT Cruiser Convertible Forum 10 08 Nov 2010 07:01 pm
