Belt confusion (stupid!-stupid!)
  • 1 Post By rob342
Old 22 May 2013, 09:20 pm
Gru's Avatar
Gru Gru is offline
Default Belt confusion (stupid!-stupid!)
There are three belts, counting the timing belt, right?
The alternator belt and the accesory belt are the other two.
Is the alternator belt a v-belt or a flat serpentine? I assume the accesory belt is a flat serpentine belt.
I am planning on replacing them both. When I go through deep puddles I hear a belt squealing so I assume one, or both, need to be replaced. I'll also do the tensioner pully then.
Sooo, I was wondering what I am looking for when I go to the parts store? Alternator belt, accesory belt, and tensioner pully? Both belts are flat?
In case I don't see you...
Good afternoon, Good evening, and Good night.
Old 22 May 2013, 09:31 pm
Default Re: Belt confusion (stupid!-stupid!)
The alternator belt should be a V belt. The serpentine is flat with ribs and the timing belt is is flat with teeth.
Old 22 May 2013, 09:56 pm
That belt is also flat belt.
Old 22 May 2013, 09:59 pm
That's why I said "should be". Thanks for the correction Danny.
Old 22 May 2013, 10:08 pm
I was into that today. Just ordered these.
Old 23 May 2013, 11:00 pm
Gru's Avatar
Gru Gru is offline
Sorry, I was called away by an emergency...
"But I'm feeling much better now."
As always, thank you so much for your kind help.
Old 23 May 2013, 11:22 pm
garyerrol's Avatar
When I replaced my belts, I let the auto parts store select the proper belts after I gave them my vehicle info.
2001 LE, Shale Green, Aftermarket Wheels, Shorty Antenna, AirRaid Cold Air Intake, Whelen Talons (amber/white) in front windshield, Whelen Talons (amber) in rear side windows, Tomar RECT25's (amber) and Whelen Slimlighter(amber) in back window. Kenwood TK-880H 45 Watt Mobile Radio, Antenex 3db antenna w/ NMO mount.
http://smg.photobucket.com/albums/v7...0PT%20Cruiser/
Ham: N9PTC
GMRS: WPQS324
Old 24 May 2013, 03:20 pm
my car does this occasionally and it's because the plug in the front air dam and part of the wheel well liner is missing. when i look at the fog light hole in my bumper i can see the AC compressor. and when i look in the wheel well i can see the crank pulley.
before getting the belts, you might try adjusting the alternator belt tension and look to make sure all your plastic is intact and in the correct place.
Busted_PT likes this.
Old 25 May 2013, 01:02 am
Gru's Avatar
Gru Gru is offline
Absolutely Rob.
But also want to change them so I know how old they are.
Old 25 May 2013, 07:55 am
Here are the ones I got for my project 1 Pt. If you look close there are inch and mm size as whell as the part numbers for Gates.
Will that do?
Stupid stupid question pluminator Interior Accessories Forum 10 24 Aug 2012 09:41 pm
STUPID!!! So now what??? rocketsigntist General PT Cruiser Discussions 2 07 Feb 2007 03:04 am
Am I just stupid or what ?! TripleJackInGA General Turbo Discussions 10 02 Oct 2003 10:40 am
