Dash lights
Old 25 May 2013, 11:09 am
Default Dash lights
Hi all
Hope you are enjoying the long weekend.
I have a problem again today set off to fill the car up.
As I am going to pick the daughter up from uni tomorrow.
On the dash cluster the TRAC OFF on the left pod and ABS on the right pod.
Are both lit all the time and I have made some short trips.
I have turned it on and off about five times today.
Has any one got any ideas as to what it may be.
And is it safe to to do a two hundred mile round trip.
Thanks.
Old 25 May 2013, 12:26 pm
Default Re: Dash lights
Here's an older thread to read:
abs/trac warning light
Old 27 May 2013, 04:08 am
I did the key turning three times but it said done.
Not sure the best way forward.
Old 27 May 2013, 10:15 am
I ok to drive. you will not have abs but you wont feel any difference unless you panic stop. The wheels will lock up and slide just like the cars of old. The track control can operate unless the abs is working. This is why both lights are on. You most likely have a bad wheel sensor. Not sure why this is not showing up on the key dance. But your brakes won't fail or not operate . So you are ok to drive it till you get a chance to figure it out.
Old 28 May 2013, 11:03 am
Hi busted
Where are the sensors what's the best to clean then with.
Is there a resistance reading to check.
Is there a plug to check it.
Thanks
Old 28 May 2013, 12:00 pm
cruserdad1976's Avatar
the sensors are on the the bracket that holds the pads I think not much way to clean them usally just replace them
Old 28 May 2013, 01:52 pm
It might be worth a shot to check the connectors to those sensors, unplug then reconnect. I had a similar issue with a Dodge Grand Caravan where the ABS light was on. I unplugged the sensors then plugged them back in - problem was gone and ABS functioned normally. Maybe it was dirt in a connection?
2005 N/A, Cool Vanilla
Adds
PT Wheel Centers, PT Valve Stem Caps
Mopar Chrome Exhaust Tip
Mopar Molded Rear Splash Guards
Mopar Rear Step Pad
K&N Filter
Pioneer Speakers/Receiver w/BlueTooth & HD Radio
Mopar Powered Sub
Dash Lights sonocativo General PT Cruiser Discussions 21 25 Jan 2015 12:23 pm
no dash lights crazyptguy Tech & Performance Forum 5 20 Aug 2012 06:19 pm
no dash lights or head lights suescruiser Welcome New PT Cruiser Members 0 14 Feb 2012 10:44 pm
Dash lights and tail lights out ab1 Tech & Performance Forum 2 01 Feb 2012 04:34 pm
05 dash lights. wompus General PT Cruiser Discussions 9 29 Dec 2010 04:14 pm
