Auto Power Window Problem
Old 27 May 2013, 01:53 am
Default Auto Power Window Problem
I've searched through the forums and haven't seen this one posted....
You know how when you press & hold for a second the front power window switches the window will retract all the way down by itself without having to hold the button down until it goes all the way down?
Well, all of a sudden, it quit working on the drivers side. It will work just fine if you hold the button for the entire time and the passenger side auto feature still works.
I know I sound like I'm whining because I have to hold that button for a few more seconds, but once you get used to it, you miss it.
Is that one switch flaking out or lost a contact point and need to be replaced?
I have a 2002 Touring Edition.
Thanks in advance for any suggestions.
Phil
Old 27 May 2013, 04:56 am
Default Re: Auto Power Window Problem
Try resetting the computer by taking off the negative battery cable for about 5 minutes. Put it back together and see if that helps.
Old 27 May 2013, 09:45 pm
Auto-down is activated when the switch is moved (against a spring tension) to its limit. Unseen without disassembling the switch, a tab on the switch rocker presses against a small momentary contact switch.
In the first picture, the upper left rocker is removed; look for the black post. The rocker tab and post relation can be seen at the upper right in picture.
Either tab or post could be damaged.
Unlike the up-down operation, auto down doesn't use the switch contacts that can pit and wear.
In the last picture, the backside of the black posts are seen (left) as black pads (circles). These press against the actual switches, the two of which are seen on the circuit board (right); the switches are gray.
I do not know, but suspect the switches control the timer chip on the circuit board, so you now have two switches and a circuit board as possible electrical failure points. Replacing the entire switch unit might be done for $25-$30 used.
Old 23 Jul 2013, 10:06 pm
Sorry that I am so late in responding Crewzin....unplugging the battery fixed it.
Thanks so much!!!
Old 23 Jul 2013, 10:09 pm
Thanks for the detailed photos & technical info, sanatanadharma. I learned a lot and I hope that it helps someone else also!
Old 26 Jul 2013, 08:12 pm
Great picture details.
Driver window auto close?? gbopper PT Cruiser Convertible Forum 9 27 Sep 2014 01:16 pm
power window control gregsguitars Interior Accessories Forum 3 25 Apr 2011 01:42 pm
Power window problem droptopman Tech & Performance Forum 2 29 Mar 2010 07:32 pm
Passenger Window Keeps Sliding Down - Auto Up/Down Not Working lornadobson General PT Cruiser Discussions 5 01 Mar 2010 07:36 pm
POWER WINDOW MOD WAYNEF Interior Accessories Forum 13 13 Jan 2005 05:40 pm
