oil pressure sensor/cyl #1 misfire
Old 30 May 2013, 12:18 pm
Default oil pressure sensor/cyl #1 misfire
I just had my oil pressure sensor changed, 2 days later engine light, code po301. Is there any possible connections between the two? I checked the plug, and it's clean. The wires are fairly new too. What should I check next? 04 cruiser, 94k. Thanks for your help, Conrad
Old 30 May 2013, 12:44 pm
Default Re: oil pressure sensor/cyl #1 misfire
Check for a vacuum leak somewhere around cylinder #1 on the intake at the seams and where the upper and lower intake come together. Also you might want to have a compression check to see if the problem is internal.
Old 30 May 2013, 07:27 pm
Yes, I do hear a slight hiss. Though it's difficult to locate. The engine light came on for two days solid, but I just drove it, starting it on 2 separate occasions, and the light didn't come on. I have to drive 200 miles tomorrow. I hope it doesn't come back on. I read that this issue could damage the catalytic convertor, I hope it doesn't. My worry is that if I'm half way and it comes on, would it be safe enough to drive home? I also read, it will just lose power, and get bad gas mileage. Do they call them idiot lights because people like me enjoy ignoring them?
Old 01 Jun 2013, 02:09 pm
get some starting fluid and spray it directly on the intake manifold at the seam, or anywhere you think there's a vacuum leak with the car running.
if you have a leak, the engine rpm will surge because the starting fluid is more combustible than fuel.
Oil Pressure sensor adventure mommacrstl Tech & Performance Forum 40 26 Jun 2017 10:31 am
Install - Oil Pressure Sensor geronimo Tech & Performance Forum 27 02 Feb 2015 04:31 pm
Oil pressure sensor: OEM or aftermarket? Strilla Tech & Performance Forum 12 13 Apr 2013 11:31 am
Oil Pressure Sensor Questions 03silvergt Tech & Performance Forum 7 05 Nov 2012 06:02 pm
releasing the oil pressure sensor geronimo General PT Cruiser Discussions 0 29 Mar 2010 03:31 pm
