What size nut?
  • 1 Post By vipergts
Old 02 Jun 2013, 07:56 pm
vipergts's Avatar
Default What size nut?
My 03 PT GT has a loose green power wire going to the starter...Its a PITA to get to...Anyone know what size nut it might be? Thanks
E1 Turbo, 3 Bar Map~Tip, 888/1025cc Duster's Injectors, Stage 1 PCM, Composite Intake Manifold, Airbox Mod With Drop In, Ported Exhaust Manifold, Walbro 255, 3 Inch Catless, Poly Mounts, Blue Plate, DCR Oil Mod, DSP, AEM A/F, FM WGA, N2mb Electronic Boost Controller, Power Demon ATX, Duster's CMR Tune, E85 Powered, Cross Driiled Rotors, BTG Springs, Mopar Ground Effects Kit, 5K HID lights and fogs, LED Tails...3080 lbs in race trim.300WHP~345 Ft Lbs Torque @ 16PSI...Now boosting 19PSI, WHP And Torque numbers coming soon.
Old 03 Jun 2013, 10:29 am
Default Re: What size nut?
i believe it's 13mm. i'll double check after work for sure if you like. my car is still apart, so i can get my hand in there.
Old 03 Jun 2013, 11:46 am
vipergts's Avatar
Thanks
Old 03 Jun 2013, 04:09 pm
vipergts's Avatar
You were correct 13mm...Thanks! Al
rob342 likes this.
what is your nut size? 4SPEED Turbo Wheels/Suspension/Handling 11 13 Apr 2011 03:01 pm
rim size bkh67 Wheels, Tires, Suspension 2 05 Aug 2010 05:33 am
Cat size KingKole02 Tech & Performance Forum 4 21 Mar 2006 01:54 pm
what size for 18'' steve smith Turbo Wheels/Suspension/Handling 2 23 Dec 2005 04:24 pm
pic size bigdogdad Testing 6 21 May 2004 04:53 pm
