Speed control does not come on, ever?
Old 04 Jun 2013, 06:09 pm
Default Speed control does not come on, ever?
Hey guys, I have a 2006 touring convertible turbo. I cannot get the cruise to turn on, as in no light on the dash and it does not hold speed. additionally, I had my friend at Autozone scan the car. I got no codes but at the very end of the report it said the transmission has overheated. We looked it up and his computer said primary cause is low transmission fluid. I checked and is was a little low.
third layer. the distance to empty/average MPG displays inaccurate data. I did a test, drove over 100 miles, filled up and did the math. The car got 24.6mpg on the highway. the gauge read 18.9. before I refilled the tank the guage said DTE was 143 and I still had just under 3?4 tank of fuel.
Any ideas? I wonder if the two problems are related?
I look forward to hearing from you!
I just bought the car about three weeks ago. no other problems, it has about 98,000 miles and I have a reciept for a timing belt replacement at 84,592 miles.
Old 04 Jun 2013, 06:27 pm
Default Re: Speed control does not come on, ever?
Wonder if anyone has changed the trans filter and fluid. If filter is dirty it could starve the pump and work the trans harder.
Old 04 Jun 2013, 07:47 pm
I've never found a " distance to empty to average MPG" to be anything but a guesstimate by the computer or what the numbers should be. They are not reliable.
Do yourself a favor and have the transaxle fully flushed and make sure they use ATF+4
Old 06 Jun 2013, 11:12 am
The MPG guage is designed to be reset at each fill up. It calculates an average, so 100 miles of highway driving will make little difference on it depenting on when it was last reset. Do the test again, but reset it after filling up, and I think you'll see the accuracy increase, although it's not designed to be spot on.
-Chris
Old 09 Jun 2013, 01:30 am
thanks for the info about the MPG thingy. Any one have help for me on the cruise control issue?
Old 09 Jun 2013, 11:27 pm
Elmo; when the engine is running, pushing the speed control on/off button should turn the 'cruise' light on or off. I typed in 'PT cruiser cruise control installation' and got a wiring diagram for a 2002 PT. And some neat pictures. Your car is different. However, it gives a general idea of how the system works.
Old 12 Jun 2013, 01:23 am
Exactly, When I push the button I get no "cruise" light and speed control does not work. I've looked everywhere for a fuse and cannot find one. no vacum leaks....I'm lost.
Old 12 Jun 2013, 01:34 am
i'm gonna go out on a limb here and suggest raising your steering wheel just a tad. there have been quite a few problems related to things not working in that area due to stress on the tight harnesses that are in or around the steering column.
2016 Kia Soul Plus Black
Old 13 Jun 2013, 04:07 am
Elmo; like soy said, some have had a steering column issue. There's an excellent post written yesterday? on the same issue in the tech section.
Old 13 Jun 2013, 02:05 pm
PT06, I looked in the tech section and could not find the post. Can you send a link to it or give me the name of the poster and the date? thanks.
Locating Radiator Fan relays High Speed and Low Speed CashReject Tech & Performance Forum 14 06 May 2017 12:12 am
p1596 speed control switch always high Chrisd069 Tech & Performance Forum 2 14 May 2012 02:42 pm
FS-Energy Susension urethane control arm kit and control arms nuptgt4me Classifieds: For Sale/Trade 0 18 Mar 2010 05:31 pm
Added OEM Speed Control - Not working bnj5008 Tech & Performance Forum 6 30 Sep 2009 06:52 pm
Is the 4 Speed A/S realy a six speed? Ian-PT-GT General Turbo Discussions 11 16 Apr 2004 10:19 pm
