Awkward Controls on 08 PT
Old 04 Jun 2013, 06:53 pm
Princess's Avatar
Default Awkward Controls on 08 PT
Not gonna bash it. I love my baby but... I got this yesterday & am curious to know if all PT 08 Base w/ upgrades have what I have.
You literally have to fight the right knob to properly move it to the position you want. Also, I have no lighter.... base comes with no lighter or did this person somehow lose it? Its a pristine car except for those two details.
...also Audio is terrible.
Old 04 Jun 2013, 07:35 pm
Default Re: Awkward Controls on 08 PT
The cruisers didn't come with any lighters except if you got it with the smokers package. I have 3 outlets in mine and they are all 12 volt sockets for accessories. As far as the hardness of turning the knobs, it shouldn't be that way unless it's the knob for inside/fresh air and that would take a little more strength because your actually moving an actuator door at the end of the cable attached to the knob to let fresh air in or stop fresh air and use recirculated air from inside the cabin.
(sent on my iPad from Memphis Tennesee in the middle of a 7 day Hot Rod Power Tour. Tomorrow ...Birmingham, Al.)
Old 04 Jun 2013, 07:37 pm
Dang gen2's
Old 04 Jun 2013, 07:41 pm
Princess's Avatar
Is the wiring already in there then for base? Its $14 on Ebay I found for the OEM Mopar bit... I didnt find the cover, But I don't want to miss anything I will need to install it myself. I need my GPS so much...and S4 Battery life is nothing amazing unfortunately. The knob isnt hard to turn...rather the system doesnt register its movement properly so you have to tinker with it which I couldnt do while driving...ie My audios stuck in fade F7 till I care to play the knob game tomorrow morning.
What I added to Cart:
Dodge Jeep Chrysler Power Outlet Cigarette Lighter Outlet Replacement Mopar | eBay
Rest is a mystery to me, but cant be that hard. and was 5,700 worth it for a base w/ everything but the lighter, power seats & cruise control? All the 06-08 I saw elsewhere were uncared for, so the moment I saw this one I nabbed it without thinking on price.
Old 04 Jun 2013, 08:11 pm
VNT's Avatar
VNT VNT is offline
Dont you know your not allowed to smoke in your cruiser
Are you talking about the temp control knob or radio, might have to press the radio knob in or pull out the detent and then turn it to adjust the balance or fade.
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Old 04 Jun 2013, 09:14 pm
Princess's Avatar
I just want to charge my phone on the go so I can use gps on trips lol I dont smoke. Also radio, when you adjust it...it fights you. Can go from 3 to 9 in 1 turn for example its nutty.
also was automatic trans a base option? Because i swore base is listed as manual, yet mines automatic.
Old 06 Jun 2013, 11:00 am
Does yours not even have the lighter socket? All models should have the socket. Models with the smoker packge will have a lighter insert, and models without will simply have a cover.
Your radio knob problem is unfortunately quite common, and the fix is to replace the radio.
Manual was the standard transmission, but all models could get an option automatic. For the last year in 2010, they were only available with automatics.
-Chris
Old 06 Jun 2013, 06:45 pm
Princess's Avatar
Oh okay. Hopefully can nab the radio from the 06 parts out (if an 06 radio will work in 08?)
Anyways nope! Not even a cover... just a hole into the dark abyss of mystery
Old 07 Jun 2013, 09:29 am
Yep, any radio from 06-10 will work. It's actually a good opportunity to install a 6-disc radio if you care about having a cd changer. For instance, a 6 disc radio out of any year Dodge Magnum or 06-10 Charger (without navigation) will also work. You can also you radios out of 06-08 Dodge 1500s, 06-09 Dodge 2500/3500s and many later model Jeeps, so your options are wide open!
And if you have the hole where the socket should go, the wiring should all be there, unless it was cut when the socket was removed. Either way, it's easy to wire in if the wiring is damaged or missing.
-Chris
Old 07 Jun 2013, 10:28 am
cruserdad1976's Avatar
and on a bright note some radios have the usb charging port built into them
Stupid AC Controls rod9669 General PT Cruiser Discussions 12 02 Jul 2012 01:53 pm
controls getting quite hot to the touch houwer Tech & Performance Forum 4 20 Aug 2010 07:06 am
What is this button below the mirror controls shilton General PT Cruiser Discussions 3 08 Jul 2010 09:20 pm
Temperature controls Eileen Tech & Performance Forum 4 03 Oct 2009 01:12 pm
heater controls 4b316 Tech & Performance Forum 1 11 Jul 2009 07:25 am
