Fog lights flickering-ignition off-no fuse
Like Tree2Likes
  • 2 Post By CREWZIN
Old 12 Jun 2013, 02:09 pm
Default Fog lights flickering-ignition off-no fuse
Can anyone help me. I have a uk model 2005 cruiser. Today the fog lights came on and wouldn't go off. Eventually, after fiddling with every button in the car they started to flicker. (i bought the car two years ago and never knew it had fog lights as they have never worked) i googled the fault but it was no help.
The main fuse box is located to the right of the steering column-about shin height. The fog light fuse is missing as I searched for it to take it out.
Now I'm clueless as to what to do. The fog lights are flickering on and off every four seconds!
Old 12 Jun 2013, 07:34 pm
Default Re: Fog lights flickering-ignition off-no fuse
Try and disconnect the wire behind each fog lamp . You may get a little dirty . Reach under the car , behind the bumper , closer to the ground , and in front of the plastic inner fender liner . That is where it can be pulled apart and disconnected. **Look at it carefully so you don't break the fog lamp bulb holder bracket ,or thingmajig **. That should stop the flashing . and it will give you some time to figure out what to do later . Cheers
Gray 2003 Base model A/C,auto, P/W , weathertec ventshade ,mostly stock so far ..
1960's Comet 4 Dr..Restomod
2004 Legacy SW. stock
Old 12 Jun 2013, 07:51 pm
According to my Owner Manual, for the export model PT Cruiser the Fog Light fuse is the #21 20 Amp fuse in the Power Distribution Center (PDC) in the engine compartment.
Old 13 Jun 2013, 01:18 am
Thank you. Fuse from bonet fuse box was located and removed last night!
I love my car but it does seem to be quite problematic
lights flickering cookieman18 General PT Cruiser Discussions 19 27 Nov 2016 10:01 pm
Flickering lights dom92 General PT Cruiser Discussions 2 01 Mar 2011 06:58 pm
Flickering lights again white General PT Cruiser Discussions 1 02 Mar 2009 04:00 pm
Flashing/Flickering lights alien88 General PT Cruiser Discussions 4 25 Nov 2008 10:19 pm
Ignition Hot Fuse Under Hood? brymck Sound and Security Forum 3 03 Jan 2008 09:14 pm
