Clock Spring in a 2003 PT Cruiser
Old 12 Jun 2013, 09:00 pm
Default Clock Spring in a 2003 PT Cruiser
My horn, air bag and cruise control quit working. From reading on here and other places I realize the problem is with the clock spring. I priced a new one and am looking at roughly $240 and that's just the part. I would be installing it myself.
My first question is: is it possible that there are just wires off behind the steering wheel or is it a case of "if the horn, air bag and cruise aren't working, it needs replaced"?
My second question is: how do you guys feel about second hand parts for something like this?
Old 12 Jun 2013, 09:57 pm
Crid's Avatar
Default Re: Clock Spring in a 2003 PT Cruiser
Just had mine replaced in my 06. It won't b wires. My horn air bag and cruise didn't work either. I recommend having someone do it as ur air bag is behind the wheel cover. But to each there own. Part cost me 260 and labour at the dealer all together 460 done. Didn't want the hastle of something else goin wrong while in there
2006 Cruiser, Non-Turbo, 19 inch Konig Trouble rims on 225/35/19 Ironman Imove tires, Airaid CAI, E3 Plugs, msd super conductor 8.5 mm wires, Freedon Design Strut Tower Brace, Glow Shift Pillar gauges, EBC Slotted Rotors with EBC Green Stuff Ceramic Fiber Core Pads, Lowerd on Tien springs, Full Custom Kenwood Excelon sound system with 1 12" JL Audio W0, 8000k Blue hids up top and aftermarket OEM Fogs with white 8000k in bumper. Ipcw Bermuda black true led taillights with tinted reverse lights.
Old 12 Jun 2013, 10:33 pm
Ray_Dockrey's Avatar
Airbag is really easy to get off. I have had mine off a couple of times. If you do a Google search you can find the instructions on installing the factory cruise control. It will show you step by step on removing the airbag and changing the clockspring. Make sure you get the instructions for 01-05. The 06 and up are a little different.
Old 13 Jun 2013, 08:24 am
Not worried about getting the airbag out. I have already had the entire dash out and removed/replaced the heater core. lol Steering wheel and airbag can't be much more friggy. Besides, I found a video and written instructions online.
I still would like to know if anyone has and opinion on using a second hand one.
Old 17 Jun 2013, 05:33 pm
Default Re: Clock Spring in a 2003 PT Cruiser UPDATED
Well as it turns out the junk yard didn't want to sell me just the clock spring. So, I had to buy the entire steering column for $100. That suited me anyways because I didn't have a steering wheel puller anyways and thought it would be easier. NOT!!
I have learned (now) that when you replace the entire column that your car will not start because the key and SKIM module aren't compatible with the car's computer. You have to move the lock cylinder and SKIM module or the anti theft will kick in and your car refuses to start.
This link will show you how to remove the lock cylinder. I didn't bother with the part about changing the tumblers, didn't need to. The first part will show you what you need to know.
The attachment shows how to remove the SKIM.
I hope this saves some time for people!!!
Happy Cruising!
Clock Spring compatability schwasskin General PT Cruiser Discussions 2 22 May 2013 09:00 pm
2002 PT Cruiser Clock Spring Re-setting? 2002Gold Tech & Performance Forum 2 03 Jan 2010 05:04 pm
i need a clock spring for my wifes 04 pt can anyone help me ?? bobs turbo pt Classifieds: Want To Buy 5 15 Jan 2009 02:26 pm
o4 clock spring needed can anyone help me ?? bobs turbo pt General PT Cruiser Discussions 1 07 Jan 2009 04:53 pm
Need airbag clock spring source Poppapug General PT Cruiser Discussions 3 15 Sep 2008 08:26 pm
