Electrical problems 03 classic..
Like Tree2Likes
  • 1 Post By CREWZIN
  • 1 Post By Busa_Powered
Old 13 Jun 2013, 12:49 pm
Exclamation Electrical problems 03 classic..
Ive been having some electrical problems for about a year now... After I drive my car non stop for about 5 miles and comes to a stop light, all the interior lights go dim and get bright again..
Repairs over the last year.....
** Changed the alternator twice
** Changed the battery 3 times ( now have a Interstate batt. )
** Switch out almost all of my stock bulbs to LEDz
** Changed headlights to HIDz ( they dont fo dim anymore like before now)
_____
Possible solutions thats im told could work but am not sure..
** reflash my computer.
** Replace the ECM PCM all together..
_____
I guess my main question is, is anyone else having this problem... and if so what can be the cause/solution.....
Old 13 Jun 2013, 01:59 pm
Default Re: Electrical problems 03 classic..
to begin with, i would check the main ground wire from the battery to the block. maybe replace it with a thicker ground wire, especially if there's any hint of green corrosion near the wire ends.
2016 Kia Soul Plus Black
Old 13 Jun 2013, 02:48 pm
Besides the above advise (which is good) you should look through the below post on the subject of Hyper Grounding. Myself and others have tried it and those with electrical problems seem to think it helps. It's a lot of reading and it starts out by explaining the grounding wires on the front struts then goes on to talk about the Hyper Grounding (extra ground straps).
ground wires from body to front struts?
04GTTurbo likes this.
Old 13 Jun 2013, 03:18 pm
Dang canbus
zamfir2 likes this.
Old 13 Jun 2013, 05:24 pm
Exclamation Re: Electrical problems 03 classic..
Thank you guys for the quick feed back.. The lines to and from my battery have all been changed out. When I first got my car 3 years ago, the green buildup was bad, it actually corroded the connector to the battery. if after grounding my car better I still have the same issues, could it be the voltage regulator in the ECM PCM??
Tags
2003, ecm, electrical, pcm
electrical problems KJT Tech & Performance Forum 6 27 May 2013 01:23 pm
Electrical Problems Nippur General PT Cruiser Discussions 2 29 Jul 2010 05:24 pm
possible electrical problems? pineapple General PT Cruiser Discussions 5 14 Jun 2010 11:57 am
PT Electrical Problems DDPTman Tech & Performance Forum 1 17 Feb 2009 03:34 pm
Electrical Problems sdalley Tech & Performance Forum 3 08 Nov 2008 06:20 pm
