2005 GT convertible service repair manual
Old 15 Jun 2013, 04:28 pm
Default 2005 GT convertible service repair manual
Anyone know where I could obtain or download a service repair manual for a 2005 GT convertible? Or do you know if the 2001-2004 service manual is the same for a 2005?
I need the wiring diagram for the turn signals so I can install aftermarket side mirrors with turn signals, and need to splice the aftermarket mirror's wires into the original turn signal wires. Also where would be the best place to splice into the turn signals? On the steering column or at the kick panels on the inside of the vehicle?
Any help is appreciated. Thanks!
Old 15 Jun 2013, 05:04 pm
Default Re: 2005 GT convertible service repair manual
Old 15 Jun 2013, 05:20 pm
front parking lights wiring diagram
rear lighting diagram:
i would tap into these. i am not a mechanic or an electrician. just seems like it would make the most sense to find the rear signal wires and tap these. should be a straighter shot if you can find these wires in the back(to verify the coloring) and then splice where they pass the front kick panels.
these diagrams are for "2005 Chrysler Truck PT Cruiser L4-2.4L Turbo VIN 8" however i would ASSume they should all be the same, since the diagrams i'm looking at even have wiring diagrams for export models. they list 4 different vin number options for the turbo models.
Old 15 Jun 2013, 06:11 pm
rob342,
Thanks for the quick reply and for posting the diagrams. I do have a turbo, vin S, but there shouldn't be much variance. That's why this forum is awesome, as members like you are always so helpful...Much appreciated.
All the best to you....
Old 04 Jan 2018, 11:06 pm
http://www.manualslib.com
Found the manual for pt cruiser for all models
Helped a lot being new the the machine
I love mine and I have only had it for about two weeks
She cold blooded don't like the in -30 degree temps
We have had
2005 pt service manual jimhoysa Tech & Performance Forum 3 30 Jul 2015 01:29 pm
Service/Repair Manual 07PTSilver General PT Cruiser Discussions 23 30 Nov 2013 09:58 am
Repair Service Manual jackcruiser General PT Cruiser Discussions 3 04 Sep 2012 05:58 pm
Repair/Service manual? sscanlan Tech & Performance Forum 8 11 Feb 2011 12:18 pm
