Overheating again!!!
Old 17 Jun 2013, 01:41 pm
Default Overheating again!!!
I have a 2003 (non-turbo) with 272,000 mi., 5-speed manual. During the first drive of every day the engine overheats, I turn on the heater and fan and the gauge immediately returns to normal temperature. I turn off the heater and the engine temperature remains normal the rest of the day, no matter what type of driving I'm doing or how often I start and stop the car. I've replaced the thermostat, radiator cap and cooling fan. Nothing seems to help. Any ideas out there?
Steve
Old 17 Jun 2013, 02:09 pm
cruserdad1976's Avatar
Default Re: Overheating again!!!
did you flush the cooling sysytem??? sounds like some kind of a blockage in the system
Old 17 Jun 2013, 03:05 pm
Yes, i had it at the dealer and they flushed it and replaced the coolant. They have not been able to find a solution either. They told me that they are at the point of just guessing what might be wrong and start replacing parts.
Old 17 Jun 2013, 03:08 pm
Vlefaive's Avatar
272,000 miles ! Nice..... Sounds like it's time to convert it into a giant cube ..... jk ....... Confirm the fan is good, it seems to always be the source of grief ..
'03 GT Blue/ autostick.. 160,000KM ( That's 100,000miles for y'all South of the border ) All the options, the heated leather is a must up here in Canada, Love the solid heavy duty feel and obvious Torque.. The Turbo is strong, fast and reliable.. People that don't understand the love of a PT, probably don't deserve to.
Old 17 Jun 2013, 03:42 pm
what about the water pump????
Old 17 Jun 2013, 06:17 pm
Water pump was replaced last summer. Dealer claims it's working OK as they see water moving through the radiator neck. I had similar problems with it 2 years ago and ended up replacing the radiator, which fixed it until 4 weeks ago. I just have a hard time believing that radiators clog up that fast...?
Old 17 Jun 2013, 11:32 pm
I would to but it is a small radiator maybe a back flushing might help and be sure to get all the air out
Old 17 Jun 2013, 11:51 pm
^^^^Try that. And you're 100% sure it's overheating?? Or you're just going by the gauge?
02' Touring
Old 18 Jun 2013, 03:37 pm
I'm going by the gauge. Is there any other way to determine if it's overheating?
Old 18 Jun 2013, 03:48 pm
You can use a code scanner that can view live data. You can get them pretty cheap on eBay. I bought a actron CP9580 for under 100 bucks and it has been useful. They will tell you temperatures, O2 voltages, iat reading, map/maf reading and etc.
overheating? pineapplesf Tech & Performance Forum 3 10 Jul 2013 05:42 pm
Overheating snowwhitetiger General PT Cruiser Discussions 7 31 Mar 2012 09:48 pm
Still Overheating Cruz2success Tech & Performance Forum 2 19 Jul 2011 10:43 pm
Overheating kporcenaluk Tech & Performance Forum 5 01 Sep 2010 08:48 pm
Overheating Once again!!!! thetinman General PT Cruiser Discussions 4 09 Jul 2010 04:23 pm
