engine oil leak
Old 18 Jun 2013, 10:22 pm
Default engine oil leak
My daughters Convertible had an engine oil leak coming from behind the timing belt. Took it to a mechanic and first he said it maybe the thrush bearing. But he is not sure he recommended an new engine due to something about the shaft having a lot of play in it. the car has less than 80K it is an 07 he claims that it has been a problem with some of the PT Cruisers out there. Daughter is still paying on the car, she had it less than a year. Any advice? Anyone know what this mechanic is talking about? Thanks for any feedback.
Old 18 Jun 2013, 11:37 pm
UptownSport's Avatar
Default Re: engine oil leak
Some of the newer engines did this-
I *think* they only used 1/2 of a thrust bearing shell- Prolly saved a nickel if that.
You could have the components 'fixed', they'd have to disassemble the engine.
To check it, just grab the harmonic balancer and pull it back-Forth
Old 19 Jun 2013, 10:14 am
it does have play in it, anyone know what the fix is?
Old 19 Jun 2013, 10:43 am
crank shaft end play
Engine leak 01limited94 General PT Cruiser Discussions 12 15 Mar 2013 01:53 pm
Engine Oil Leak Ikster Tech & Performance Forum 2 01 Mar 2013 05:29 pm
Engine coolant leak help Vicky Tech & Performance Forum 9 25 Jul 2012 04:22 pm
Engine Oil Leak Ikster Tech & Performance Forum 9 30 Apr 2012 09:36 pm
Engine Oil Leak rcalzadilla Tech & Performance Forum 10 24 Sep 2009 08:25 pm
