need help with C/C install
Old 19 Jun 2013, 02:20 pm
vgbu56's Avatar
Default need help with C/C install
I have a 2004 base model, it has the wire/plug for the actuator, but my clock spring only has 3 wires not 5 wires, the connector plug from the car wire harness to the clock spring has 5 wires. So do I get a different clock spring or is this where the kits have wire to be inserted into the clock spring which would then plug into the switch, All my parts are from junkyard PT's that came with cruise. Has anyone cut the C/C switch wires off an old clock spring and inserted them in there clock spring with any sucess, if so what did you use to keep then in the connector? will I need to have the computer flashed?
i-Pod Install smallfrycruzr Sound and Security Forum 4 12 May 2010 07:31 am
help with install utmmusicman Sound and Security Forum 7 17 May 2007 05:53 am
Self install?? nuke72 General Turbo Discussions 3 15 Apr 2006 01:36 pm
AGP WGA install hoopdiewagon General Turbo Discussions 2 08 Jan 2005 01:42 am
BOV Install RODRUN Stage Turbo Kits 7 12 Oct 2003 11:27 am
