Oil Leak
  • 1 Post By Busted_PT
Old 19 Jun 2013, 06:52 pm
Default Oil Leak
Ok, I have a 2001 Pt Cruiser Limited 2.4L non-turbo. Bought it about 2 years ago, now it has 168,000 miles on it. This car has been great to me except for one thing, there is always an oil leak. It was leaking from the pan gasket, fixed that and it immediately started leaking from somewhere else. Now the pan gasket is bone dry but there is still oil coming from somewhere on the passenger side of the engine. Its really crammed together under there so I cant tell where its coming from, but the bulk of the oil is dripping off of my a/c compressor. Its motor oil for sure, not compressor oil because my oil level is going down slowly, about 1/2 a quart a month. My best guess is the crankshaft seal. All other fluids are full. I'm open to thoughts or suggestions at this point.
Old 20 Jun 2013, 12:27 am
Chriscokid's Avatar
Default Re: Oil Leak
By your mileage, it looks like a timing belt change is coming up. When I did mine at 95000, I had my mechanic replace every seal that could reasonably be done. Maybe at that rate of leakage, it might be better to wait to everything is exposed. Just a thought. Good cruizin
[SIGPIC][/SIGPIC]2005 PT GT Vert
2004 Honda Aquatrax turbo Jetski
2006 Honda Aquatrax
1998 Dolphin 36' motor home
1949 Piper Clipper taildragger
Old 20 Jun 2013, 07:43 am
If on the ac I would guess more likely the Crank is not the problem. The valve cover is one of the most likely culprits.
Vlefaive likes this.
Old 20 Jun 2013, 10:31 pm
Ok Thanks! I've got an oil change coming up so like a week before I will put some UV dye in it and when i get under there to change the oil ill see then. Im kinda putting off a timing belt change since I do all my own work and by looking at the engine compartment I can tell the timing belt is gunna be a pain!
Old 21 Jun 2013, 07:44 am
Lots of helpful pic and how to's on here for the belt change.
Old 21 Jun 2013, 04:03 pm
Ok ill look into that. Thanks!
Tags
crankshaft seal, oil leak
Oil Leak, Vacuum leak Ikster Tech & Performance Forum 1 02 Jan 2013 09:53 pm
07 PT with Oil Leak jstcuz Tech & Performance Forum 14 10 May 2012 01:03 pm
Odd Oil Leak GTPT Turbo Performance 5 27 Aug 2004 03:39 pm
ATF Leak shlalk General PT Cruiser Discussions 12 24 Mar 2004 09:05 am
First Oil Leak? Ack! beebs General PT Cruiser Discussions 4 18 Oct 2003 10:55 am
