AC not cooling
Old 24 Jun 2013, 08:20 pm
Question AC not cooling
It's getting tougher for a shade tree machanic to work on these new cars. I have recharged vechicle ac various times over the years but not sure about this one. compressor keeps kicking on and off as though it low on freon. but all I have in the one gauge for the low side and it's in the red as though there may be too much freon. Bottom line is the system just blows cool air but not cold. Any thoughts?? It's a 2002 pt cruiser.
Old 24 Jun 2013, 09:48 pm
Default Re: AC not cooling
do a search for the radiator fan. it has 2 speeds and they're prone to go bad in our cars. chances are the high speed is shot, which cools the compressor. you should hear it when you turn the a/c on.
2016 Kia Soul Plus Black
Old 24 Jun 2013, 09:58 pm
^^^Agree check your fan, you should be able to hear it when it's on high.
02' Touring
Old 25 Jun 2013, 01:00 am
randyincctx's Avatar
Lightbulb Re: AC not cooling
I used A/C Pro on my truck over a year ago,and it STILL freezes Balls!!!!!........I don't know if anyone here has used it,but it worked for me....and it SEALS LEAKS too.Car Air Conditioning Recharge Products AC PRO, ACP 100, ACP 102, ACP 101
Aka:~KILLER~
Old 25 Jun 2013, 06:13 am
Fan is running and in hi speed. I became aware of the fan system with my son's 03 pt. Motor burned up in it.
Old 26 Jun 2013, 09:26 pm
Matt42's Avatar
It's getting tougher for a shade tree machanic to work on these new cars. I have recharged vehicle ac various times over the years but not sure about this one. compressor keeps kicking on and off as though it low on freon. but all I have in the one gauge for the low side and it's in the red as though there may be too much freon. Bottom line is the system just blows cool air but not cold. Any thoughts?? It's a 2002 pt cruiser.
If I understand your post correctly, you have one gauge and not a two gauge set. Is that right? If that's so, you are right, it'll be more difficult to diagnose refrigerant problems.
Does your gauge just have colors, or does it also have pressures on it? So by being in the red, can I assume that the pressure is too high, as you have indicated? That can indicate that moisture has gotten into the lines, if I recall correctly. Vacuuming the lines is a first step. Then it's a good idea to see how long the system will hold vacuum. If it won't hold 29 inches (depending on your altitude) for 15 or so minutes, there are problems. If there has been moisture for quite a while, the accumulator is likely contaminated and should be replaced. But if it holds vacuum, I don't replace the accumulator.
So if it holds vacuum for 15+ minutes, I go ahead and refill the system with R-134 using a thermometer in the center A/C vent, with the setting on maximum recirculate, engine at 1500 RPM in neutral, windows closed. I never put in more R-134 than the sticker under the hood calls for, and I'll err on the side of less. (My truck performs better than 2 ounces less than the 34 ounces stated on the sticker.) I stop filling when the minimum temperature is reached, but also watching the manifold gauges to make sure that nothing is going wrong. It's good to have someone in the car to watch engine temperature, also.
What's the year of your car and where do you live? Those affect what can be wrong. Old car, hot climate, high mileage add up to problems. Do not ask how I know.
What I have described is what I do, and is completely from memory. It may not apply to you. Good luck.
1996 Dodge diesel 4X4, 2001 PT Cruiser Touring with rear disc brakes, [Now gone 2004 PT Cruiser Base 5 speed], 2007 Chrysler T&C Touring
Old 27 Jun 2013, 08:40 am
I had an issue with mine this spring (pressure switch popped out of back of compressor). It wouldn't come on. When I put the gauge on it, it was in the red. Once it was working, it read normal pressure. I read on other sites that if the system isn't running, it may cause the gauge to read red even if it is at proper pressure.
Old 27 Jun 2013, 04:43 pm
I can vouch for the above, if the system isn't on it'll read red, I had that today trying to diagnose an overheat issue. Last summer I had to replace the fan, all relays and fuses were good and it looks like that's the issue again but damn am I going to have to put a fan a year in this thing that's a lot of money. any ideas on whats could cause the fan to burn out that fast?
Old 27 Jun 2013, 07:10 pm
is it a dorman fan? if so, there's a lifetime warranty. if not, couldn't tell you. if you have to buy another fan, get a dorman. amazon and rockauto have them for less than $100.
Old 28 Jun 2013, 02:05 pm
not sure, I'll have to ask the mechanic my fiancÚ took it to, thank you I'll make sure we get one of those this time
Installed and new cooling fan and cooling temp sensor & still the fan doesn't kick in rdvarona Southeast PT Forum 18 31 May 2013 09:14 pm
cooling fan cowboyinboxers Tech & Performance Forum 3 16 Aug 2011 02:25 pm
Cooling Fan bciardelli General PT Cruiser Discussions 1 02 Jun 2011 04:41 pm
GT cooling fan 4SPEED General PT Cruiser Discussions 1 14 Mar 2011 03:17 pm
A/C not cooling at all bigjoe1651 Tech & Performance Forum 5 10 Oct 2009 02:42 pm
