HELP!! lights, blinkers, & wipers all not working
Old 26 Jun 2013, 10:53 am
Default HELP!! lights, blinkers, & wipers all not working
Hi, new here. Thanks in advance for your help. Car is an 06, mfg date of 10/ 05.Headlights, blinkers, and wipers all went out at once. I did a search here and all I found was to replace mfs, I did. I spent $103 on it put it in and nothing changed. Please help!! Thanks
Old 26 Jun 2013, 11:43 am
Ray_Dockrey's Avatar
Default Re: HELP!! lights, blinkers, & wipers all not working
Start with unhooking the battery for ten minutes. While unhooked press the brake a few times to help rid of any residual power. Then hook it back up and see if this helps.
It wouldn't be the MFS as the wipers aren't working either and those are on a different stalk. By doing the battery disconnect that will reset the TIPM which I suspect is the issue.
Let us know if the battery disconnect helps. If not a trip to the dealer may be in order.
Old 26 Jun 2013, 11:58 am
sonocativo's Avatar
Also, if you didn't damage either MFS you can return the new one and get your money back. I had issues which I thought was my MFS in my 02, Oriellys where I got mine, took it back, no questions.
Old 26 Jun 2013, 12:07 pm
Wow!! great stuff quick replies thank you very very much! I bought mine from a Stealership, oops, it was in stock. I don't know if they will take it back , anybody want to buy one?? Lol any other suggestions out there just in case?
Old 26 Jun 2013, 12:12 pm
sonocativo's Avatar
Call and ask, just say you found a loose wire and never used it.
( as long as you didn't crack/scratch, or damage it in any way )
Old 26 Jun 2013, 12:26 pm
wow you guys are great yes they are going to take it back!! I might like this better than my motorcycle forum especially if the battery trick works for me you guys are golden!!
Old 26 Jun 2013, 01:33 pm
Here is some info on the TIPM.
Totally Integrated Power Module - FYI
Old 26 Jun 2013, 02:35 pm
Ray, your first response was a relief, your most recent has my wallet feeling scared.
I hope the reset works! :-)
sonocativo likes this.
Old 26 Jun 2013, 03:10 pm
I am sorry. I wasn't trying to scare you. Just trying to educate you on the TIPM. You might also check all the connections under the steering column too if the battery reset doesn't work. Just let us know so we can do our best to help you out.
Old 26 Jun 2013, 04:08 pm
Will do. The Cruiser is the Gf's so I have to get it to my house still, but I will keep you posted.
Wipers working when off bkh123 Welcome New PT Cruiser Members 0 07 Nov 2011 01:29 pm
Help!!! Simultaneously pwr windows, sterio, blinkers, wipers; etc. went out! '02 PT MulattoQueen General PT Cruiser Discussions 4 18 Sep 2011 02:16 am
Wipers Stop Working GAPT General PT Cruiser Discussions 19 20 Mar 2010 09:46 pm
Blinkers and Hazards not working badgingles Tech & Performance Forum 1 03 Sep 2009 08:55 pm
