E Brake Light won't go off
Old 30 Jun 2013, 12:16 pm
Default E Brake Light won't go off
This just started recently. We would release the E brake and the light would stay on. Pull the brake a little and then back off and the light would go out. Did that several times. Now it won't go off at all.
Sticky or bad switch? Brake is off I tested that. The car won't move with it on and is fine when off but the light still glows.
Old 30 Jun 2013, 12:20 pm
Default Re: E Brake Light won't go off
Check inside the console to see if something is stuck or interfering with the switch.
Old 30 Jun 2013, 12:22 pm
if you are good at working on things, you should be able to figure out the problem pretty easily. this is what the switch consists of.
Old 15 Jul 2013, 12:11 am
I had the timing belt replaced by my mechanic the other day and I was talking to him about the ebrake light and he noticed it too. So he checked the brake fluid and it was low. The light went off!! Learn something new every day.
Old 15 Jul 2013, 01:48 am
Ariz; thanks for the tip!
ABS Light, Parking Brake Light, Traction Control Light kupothechocobo General PT Cruiser Discussions 9 28 Feb 2017 01:56 pm
Showing ABS light, Brake light, Traction light on Dash fox50h Tech & Performance Forum 19 18 Feb 2014 11:40 pm
Parking Brake/Brake Dash Light PhxPT Tech & Performance Forum 4 24 Jan 2013 08:41 am
Brake Light Condensation/Tail Light Replacement? NewPTCruiserInPA Tech & Performance Forum 3 23 Jul 2012 09:05 pm
tail light broken, but brake light works dirtydmix General PT Cruiser Discussions 8 09 Mar 2011 09:59 pm
