Door lock reversed
Old 05 Jul 2013, 11:00 am
Default Door lock reversed
Hi there, new member here. Although I've been reading these forums for awhile to find help fixing various parts on my wife's 01 PT Cruiser. Thanks already for the grief and money you've saved me.
Earlier in the week my wife accidentally locked herself out of the car. She thought she hit the unlock button but ended up locking the car with the keys in the ignition.
Then two days ago we both went to the grocery store. I hit the unlock on the passenger door lock switch and my wife tells me I locked it. I knew I hit the unlock button, so I checked the button. I pushed unlock and it locks and if I push lock it unlocks!
Then when we returned home from the store we tried the locks again and everything works normally.
What in the world is going on with my door locks? At this point, I'm waiting to see if they act up again.
Old 05 Jul 2013, 11:19 am
Default Re: Door lock reversed
How did you get the PT unlocked in the first instance? Did someone just use a Slim Jim or some other means of unlocking the car?
You can try resetting the computer by taking the negative battery off for a few minutes to see if that helps but if it just happened that one time, you won't know if it's fixed until it happen again.
Meanwhile, for just a couple dollars, you can have a key made that doesn't have the chip in it but will open the doors if you lock yourself out and you can carry it in your wallet/purse.
P.S. Welcome to the forum.
Old 05 Jul 2013, 11:29 am
Local police used some sort of gizmo on the drivers side door jam to wedge the door open enough to reach in with a stick to hit the unlock button. (They apparently tried a slim jim without success first)
New Door lock Pins WolfmanG Interior Accessories Forum 2 05 Jun 2011 08:17 pm
DOOR LOCK PROBLEM smiley87 General PT Cruiser Discussions 3 05 Oct 2008 08:38 am
Automated Door Lock topgunffx General PT Cruiser Discussions 1 21 Mar 2008 09:18 pm
door lock pins ote69 Interior Accessories Forum 6 06 Apr 2004 11:28 am
MGW Door Lock Pins GTSteve Interior Accessories Forum 5 26 Oct 2003 06:45 pm
