What Tools To Remove And Install Drum Brake Springs?
Like Tree2Likes
  • 1 Post By CREWZIN
  • 1 Post By bob2006
Old 07 Jul 2013, 10:40 am
Default What Tools To Remove And Install Drum Brake Springs?
Last nite for some reason one of my rear drum brakes seized up.
I figure it was probably because I was working on the front and had it jacked up high with the hand brake on so it self adjusted to the point of no movement.
In order to reset the brake I cleaned,disassembled and re-assembled it.
The hardest part of the deal was getting the springs back on, especially the top one.
So the question is:
Is there a tool that is specially made of this type of spring configuration?
I Googled around but the tools I see don't look like they will work on the PT's drum brakes.
Thanks for any help on this.
Old 07 Jul 2013, 01:44 pm
Default Re: What Tools To Remove And Install Drum Brake Springs?
There is a special tool with a hook on it for the spring. You can see it in the picture below.
Here's the whole tool with an end on it to do the little springs in the center of the shoes.
Old 07 Jul 2013, 02:12 pm
randyincctx's Avatar
Thumbs up Re: What Tools To Remove And Install Drum Brake Springs?
If you don't have one,you can check most big name parts stores(Autozone) should have 'loan-a-tool' program.....You leave a deposit for the tool,and get your $ back when you return the tool.
Aka:~KILLER~
Old 07 Jul 2013, 02:13 pm
Thanks CREWZIN
That looks like it will do the trick.
Although the hole on my PT's brakes is right up against the "shoe" I think there will be enough clearance.
Given that this is what people are using I assume it won't mar the new shoe going in.
Should I be putting some sort of protective layer on the pad where the pliers make contact?
Old 07 Jul 2013, 02:16 pm
Wink Re: What Tools To Remove And Install Drum Brake Springs?
Aka:~KILLER~
Old 07 Jul 2013, 02:18 pm
Although you can't see it, the part that touches the pad is flat and lays against the pad, not hurting it. It looks pointy in the picture but there's a flat end on it.
Good idea from randyincctx about borrowing the tool.
randyincctx likes this.
Old 07 Jul 2013, 02:20 pm
Thanks randyincctx
I saw this video but my PT's springs aren't configured that way.
The springs are similar to what CREWZIN posted only a little longer.
However I really do appreciate your help. Thanks again
Old 07 Jul 2013, 02:21 pm
Why buy something you may only use once(maybe twice) in 3-5 years....When you can borrow for FREE,I always say!lol
Aka:~KILLER~
Old 07 Jul 2013, 02:23 pm
Thanks for the fast reply CREWZIN
I am going to buy me one of those pliers before my next drum brake job.
Also I don't see where randyincctx posted about borrowing the tool. I only see the video at my end.
Edit: Ok I see the post from randyincctx now. My browser did not refresh properly.
I would buy one because I look after more then one car and it will come in handy. This was the fourth time I could have used it in the last 24 months. Struggling with those springs is a real PITA.
Old 07 Jul 2013, 02:25 pm
His post on borrowing was No#3 on this thread.
(R) brake drum squeeling/ new brake Ptcruisershort General PT Cruiser Discussions 6 25 Apr 2012 03:58 pm
03 Drum Brake Setup Q's Ptcruisershort Tech & Performance Forum 8 07 Apr 2012 02:35 pm
Brake drum diameter Afitch628 Wheels, Tires, Suspension 1 30 Jul 2010 05:02 pm
Drum brake replacement Parking brake cable Dorkygrin General PT Cruiser Discussions 2 28 Mar 2009 07:53 pm
Drum Brake Cover Herschel Turbo Wheels/Suspension/Handling 3 11 Jul 2005 08:05 pm
