what these error codes really mean?
Old 11 Jul 2013, 05:21 pm
Default what these error codes really mean?
hi
I am sorrry but I am not sure what the error codes I get with the on off on off on key really mean:
P1653 Oil Level Lamp Control Circuit
P2100 Throttle Actuator Control (TAC) Motor Control Circuit
Any help please?
Cheers from Spain.
Old 11 Jul 2013, 05:47 pm
randyincctx's Avatar
Question Re: what these error codes really mean?
What exactly is your PT Cruiser doing?....Symptoms?.....And have your tried to do a code reset?
Aka:~KILLER~
Old 11 Jul 2013, 07:22 pm
Default Re: what these error codes really mean?
Been searching for awhile for the reason you got those codes. As far as I can tell, nobody on this forum ever had them. The closest I could find for both of them is something to do with the IAC (Idle Air Controller) for the P2100 and the Oil Pressure Sending Switch for the P1653 although in the U.S. we would see the P0522 vs P1653 and P0505 vs P2100.
Old 13 Jul 2013, 06:28 pm
Thanks for your help.
I dont know how to reset the errors. I dont
have an special code reader to resset them, I
used the key and the on off trick to read them.
I feel really nothing special but only like the motor
wants to almost stop when the AC is on and the car
is stopped and in neutral position.
It is a 1.6 only
Thanks again.
Old 13 Jul 2013, 07:15 pm
To reset the codes on the U.S. cars, take off the negative battery cable for about 5 minutes. Step on the brake pedal while the cable is off to get rid of any residual charge and then put the cable back on. The car might run a little rough for a minute or two while the computer re-learns your settings. This re-sets your fault codes and the computer.
Old 18 Jul 2013, 03:55 pm
sorry for the delay.
I will try to reset the codes and
see if they appear again.
thanks a lot.
Error codes 301 and 441 kowalski4 Tech & Performance Forum 0 10 May 2012 11:39 pm
Error Codes Error lilcruiser Tech & Performance Forum 2 10 May 2012 05:34 am
no error codes lt4supr Tech & Performance Forum 4 14 Aug 2009 07:34 pm
i got error codes what do they mean feefeethaflee Tech & Performance Forum 3 31 Jul 2009 08:41 pm
Error codes mr.troy Tech & Performance Forum 3 16 Jan 2007 04:26 pm
