How to Change your Thermostat [Video]
  • 1 Post By dogfish246
Old 13 Jul 2013, 07:22 pm
Default How to Change your Thermostat [Video]
Hey guys,
So I made a video to show people how to change the thermostat on our PT Cruisers.
How to Change a Thermostat in a PT Cruiser - YouTube
Let me know what you think.
UptownSport likes this.
Old 13 Jul 2013, 07:39 pm
Default Re: How to Change your Thermostat [Video]
Very good. For future reference, the bolts for the thermostat housing take 110 in-lbs if your using a torque wrench.
Old 13 Jul 2013, 09:26 pm
Nice video....
A couple points to note:
Metric wrenches would be the proper tools for a PT Cruiser. Although you can if carefully used in a pinch the ones mentioned in the video.
There is a drain plug at the lower tank of most all radiators that can be used to drain just enough coolant to do this procedure. You will get less coolant over your working area which will ease in looking for leaks when the job is completed.
Most MOPAR thermostats come with a "giggle valve" in the mounting plate. As indicated by the factory service manual. It is to allow air to escape from the top of the cooling system, aiding filling, and avoiding steam pockets. A good idea if the replacement thermostat used does not have one drill a 1/16" hole near the outer diameter of the thermostat which will work with the same effect.
The radiator cap should be replaced at the time of changing a thermostat.
A short test drive should be done to allow the complete power plant to heat to operating temperature and the thermostat to cycle a couple of times.
Then when engine temperature allow the checking of coolant levels and the bleeding of the system.
The 45209 Stant used in the video is a 195 degree thermostat which is an excellent quality replacement thermostat.
Old 20 Jul 2013, 08:10 pm
Awesome thanks! I will add it in the annotations!
Old 20 Jul 2013, 08:12 pm
Originally Posted by NitroPT View Post
Nice video....
Great info thanks!
Old 15 Feb 2014, 10:47 pm
Two things I'd add to the video are , you want to lay a straight edge across the bottom of the plastic thermostat housing to check that the mating surface is flat. I've found that the brass inserts are a bit higher than the middle of the housing. I use a fine file or a piece of glass with fine sand paper as a good surface to take off the high area.
When installing the bolts, lay a piece of paper towel or thin cloth across the socket opening, then push the bolt head into the socket making it a snug fit. This will hold the bolt until you get it started and you will not have to try to reach down and hold the bolt in the socket with your fingers.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 16 Feb 2014, 02:08 am
midnite72's Avatar
Send a message via AIM to midnite72 Send a message via MSN to midnite72 Send a message via Yahoo to midnite72 Send a message via Skype™ to midnite72
awesome!
I'm changing to a 165 thermostat soon!
Vroom, Vroom, BABY!
Old 17 Feb 2014, 06:55 am
Midnite; your computer might not be happy with a 165* .
Old 04 Mar 2014, 01:35 pm
Changing my thermostat to a 180 because I find the fan is always coming on even in the Winter.
Also changing over to to G-06 HOAT antifreeze.
Tags
coolant, location, overheat, replace, thermostat
How to change thermostat in 06 turbo pt cruiser? sittinpretty General Turbo Discussions 9 31 Oct 2013 07:54 pm
Replaced Thermostat 06 PT Getting Engine Light ERROR P0128 Coolant Thermostat aluisi Tech & Performance Forum 1 20 Nov 2012 06:47 pm
pt thermostat rdpar General PT Cruiser Discussions 6 15 Jul 2012 04:52 pm
Fuel economy change with tire size change? Calab Tech & Performance Forum 7 11 Aug 2011 06:24 pm
How to change the thermostat? ProDigit General PT Cruiser Discussions 12 03 Feb 2011 10:38 am
