Not cranking but have power
Like Tree3Likes
Old 15 Jul 2013, 08:39 pm
Unhappy Not cranking but have power
Hi all,
So I'm in that "my POS cruiser won't start" stage of ownership.
Symptoms include not starting! It'll run fine, but it doesn't crank. Not even a peep from a relay. It's worse when it's hot out, and now it's not even trying.
I have a new battery (old one was a walmart special that leaked at the positive terminal)
I was able to activate the starter by using a 12V line to the small connector plug on the solenoid of the starter (Yay starter passed)
Also, when the wife turned the key, no signal. so it's between the battery and the solenoid.
Part of me wants to think it's the ignition switch behind the key, but I don't see that a common failure.
I hear ramblings about the TIPM, corroded harnesses, and relays.
Most auto parts stores say I don't have a TIPM and they sold me a relay, however I can't find it's location to test, let alone replace.
Any other thoughts?
i'm just very nervous about replacing a VERY expensive part ($1K @ dealer, 408 Autozone +$200 core) when we have a surgery tomorrow, and A/C that is being replaced, and a mother in law that we owe $8K
Old 15 Jul 2013, 09:09 pm
Default Re: Not cranking but have power
Originally Posted by eline65 View Post
Hi all,
Any other thoughts?
We need to know as much as the auto parts store. We have no idea what you own. Year model ect. Mileage. I'm thinking your right On the ignition.
Old 15 Jul 2013, 09:14 pm
randyincctx's Avatar
Talking Re: Not cranking but have power
You mean to tell me 'Carnac the Magnificent' isn't a member?.......LOL
Aka:~KILLER~
Old 31 Jul 2013, 03:12 pm
We need to know as much as the auto parts store. We have no idea what you own. Year model etc. Mileage. I'm thinking you're right On the ignition.
Sorry, it's a 2006 Touring w/ 140K miles. Auto Zone, Napa, and the O'Reilly in my area stores don't show a TIPM as part of my car (even when I show it to them) I returned the "starter relay" that O'Reilly sold me.
And an update, when I move the shifter, I get a 70% success rate on getting the starter to work with the key. Starter still works great when I apply 12V to the solderless connector on the solenoid. So I'm thinking of narrowing it down to the position sensor, but still want other peoples thoughts before proceeding.
Thanks,
Old 31 Jul 2013, 03:43 pm
Question Re: Not cranking but have power
You still didn't say whether you have an automatic or manual transmission?......You mentioned 'a shifter' but both transmissions have shifters.
Aka:~KILLER~
Old 01 Aug 2013, 11:30 am
Opps! It's an automatic. I move the shifter from Park to 1st, then to Park again.
The car stranded my wife and 5yo girl in Tempe last week because of this. The aftermarket remote key popped open after repeated tries to start the car. So while my bypass switch did turn the engine (with the help of a store employee to figure it out while talking to her on a cell phone), it wouldn't stay running without that RFID chip near the ignition switch. My darling wife didn't understand how the chip works and that she needed to put the key back together (or even knew how for that matter) so she was stuck.
So now she doesn't trust my "POS" cruiser to go fetch her Kia that broke down Monday 125 miles from home in the middle of BFE, with no cell service.
[sarcasm]I don't understand why she wouldn't want to be stranded a 3rd time in one month![/sarcasm]
Thus, I'm anxious to get this fixed.
Oh and the a/c I was refering to was for the home. And the surgery went well btw.
Old 01 Aug 2013, 12:28 pm
Lightbulb Re: Not cranking but have power
OK....Now I think understand what it might be....I have heard of Gen-2 (and Gen-1 also) PT Cruisers having problems with the SKIM module going bad,and I think it makes it worse on Gen2 because of the Can-Buss system.......But,some of the guys may have another idea if it could be something else,but I think my idea is at least in the right ballpark based on the info you've provided.
See:
http://www.justanswer.com/chrysler/6...on-switch.html
Also see: http://www.justanswer.com/chrysler/4...r-started.html
Aka:~KILLER~
Old 01 Aug 2013, 02:52 pm
See:
This might be a possibility. I know the SKIM prevents the car from running, but I think it still allows the starter to turn the engine. I saw this when my locksmith was encoding new keys for the car over a year ago. The unrecognized key wouldn't allow the car to keep running, and the red "armed" light would blink when the ignition was.
It's also what my wife experienced the other week (and it's heard while on the phone with her that day) when the remote key opened and the internal electronics fell to the floor of the car, so my wife put them on the passenger seat. All she was using at this point was an empty remote case with the key. A little like this but it was cut for the tumblers
http://www.keyless-remotes.com/catal..._A_250x250.jpg
The starter would only engage via my bypass since the trying to start with the key did nothing, the engine then turn, start running (ignition was on), then just die as if the key was turned off.
My issue differs from that scenario where I get no starter activity, but if it does turn over (usually after moving the shifter as stated before) the engine runs w/o issue.
well I'm not getting any codes to match this persons issue so for now, I'll put this possibility on the bottom of the root-cause list.
So... no blinking lights, or prevention of running to indicate the SKIM might the issue, nor am I getting any codes (but i did have the engine light yesterday but I assumed it was related to the gas cap since I also saw the word GASCAP where the milage usually is) I reseated the cap and the word went away, and 20 minutes later, the engine light went away too. I'll have the auto parts store check it out anyway
As the research continues, I found this ptcruiserlinks.com 35869-ignition-switch-malfunction-actuator-pin l
So I'm not yet discounting that possibility either, infact, it got bumped to #2 on the list. actually, it was my first thought now that I think about it.
I'm so lost! and too broke to be throwing parts at it!
Old 01 Aug 2013, 03:05 pm
How about something to do with the gearshift interlock system? Won't let you start the car while it's in gear and if something is wrong, when you move the shifter, it lets the interlock work correctly and start the car.
Old 01 Aug 2013, 03:13 pm
Thumbs up Re: Not cranking but have power
I thought about that also,until the mention of it working when holding the key close to the ignition....That's when the SKIM idea came to mind.....But yeah until then I was thinking 'shift interlock cable' and/or ignition switch when it was mentioned about wiggling the gearshifter?....I think we're in the right ballpark,now to figure out which base!lol
Aka:~KILLER~
Tags
crank, shift interlock, starter, tipm
PT Won't Start, No Codes, No Cranking... pink_lemur13 General PT Cruiser Discussions 4 06 Apr 2013 11:39 am
pt tries to start and does after long time cranking woodslip Tech & Performance Forum 8 27 Oct 2012 03:02 am
10 Degrees Out, Cranking but no start stixboy General PT Cruiser Discussions 21 17 Feb 2011 09:36 pm
Cranking but not starting. SiRPt3 Tech & Performance Forum 2 23 Dec 2010 10:00 pm
long cranking 4b316 Tech & Performance Forum 3 05 Aug 2008 07:34 am
